Siegfried Meier
What considerations must be made when only mounting a toroid inside an external case? The IEC input and grounding would be the same, but is it feasible to run the AC voltage from the output of the trafo a few feet with success, through a cable and 4 or 5 pin XLR connectors? I assume yes, but it "feels" weird to leave the PSU inside the main chassis and remove only the trafo.
Any thoughts appreciated.
Sig
Sig
