New API 525 build thread.
« on: December 10, 2011, 01:41:09 AM »
This will be the official new design 525 build resource.
I'll add stuff throughout the day.
Biggun http://lazpro.com/525Cschbg.jpg
This version can have a Lundahl LL1540 transformer on the front, or a differential input opamp. If using the opamp (A4)......
A4 bom http://lazpro.com/525A4BOM.txt
The 2520 overlay and bom.....
Biggerer http://lazpro.com/laz2520.jpg
Rs 16 & 17 need] to be 1/2W, the rest 1/4W.
As some BC184C batches seem to be a bit dodgy, use 550C instead.
The switch and meter board.......
The switch resistors need to be miniature types. R9-17 should not protrude through the pcb.
Don't solder in the switch until you offer it into the metalwork, as it sits off the pcb by roughly a mm.
SWMTR bom. http://lazpro.com/SWMTRBOM.txt
The main board...
Main board bom http://lazpro.com/525MAINBOM.txt
« Last Edit: January 23, 2012, 08:53:46 AM by peter purpose »
http://www.lazpro.com
I reserve the right to not sell to idiots
Re: New API 525 build thread.
« Reply #1 on: December 10, 2011, 11:14:10 PM »
Boms added.
« Reply #2 on: December 11, 2011, 01:27:08 AM »
Updated boms. Changed C15/16 to 1000uf/25v and added pins and sockets.
jsteiger
« Reply #3 on: December 11, 2011, 01:46:17 AM »
Peter, I am wondering why A2 is the dog's danglers?  ;D
Visit the CAPI store at http://www.capi-gear.com
CAPI is not affiliated with, endorsed by, or sponsored by API.
« Reply #4 on: December 11, 2011, 02:45:41 AM »
Because I couldn't fit 'you lot are a bunch of bastards' in the box.
zayance
« Reply #5 on: January 14, 2012, 11:42:58 AM »
Anybody found the 1K and 1M pots Log pots needed for this build? They need to be small so not much options from what i see...
Thanks a lot.
jsteiger
« Reply #6 on: January 14, 2012, 12:13:57 PM »
Thanks a lot.
Sorry for being a pimp but I have 1k logs. http://classicapi.com/catalog/index.php?cPath=50_131
FWIW, I have 250pc of 2623-1 due in the 1st week of February. Once those arrive, I will be opening them up for individual purchase again.
Pardon me, Jeff
zayance
« Reply #7 on: January 14, 2012, 02:57:25 PM »
Thanks a lot.
Pardon me, Jeff
Allright, then the 1K's will be added to my shopping card at your place, they should fit, thanks Jeff
Now let's hunt for the 1M again....
EDIT: I guess these would do as well, forgot about the small alpha's, but won't fit the small Api knobs tough...
http://www.banzaimusic.com/Alpha-12mm/
« Last Edit: January 14, 2012, 03:17:11 PM by zayance »
mulletchuck
« Reply #8 on: January 14, 2012, 07:31:10 PM »
Howdy peter.  nothin' against your 2520 design, but i'm assuming that the Gar2520 will work as well?   I'm familiar with building that version of the 2520, and am hoping your pcb uses the same footprint, and thus opens up the doors for the gar1731 and the other DOAs that are pin compatible with the 2520..
www.youtube.com/mulletchuck for all my recordings
zayance
« Reply #9 on: January 14, 2012, 08:16:46 PM »
2520 footprints are all the same, only diff could be the pin socket size, but if you get them from Jeff then you're good to go....
zayance
« Reply #10 on: January 15, 2012, 07:26:53 AM »
Allright i think i found another solution, i tought these won't fit but....
So for the 1M pot will be using the CT ones found at Digikey as well as Mouser as well as banzai iirc.
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&itemSeq=109386570&uq=634622023213144546
The 1M would fit but you need to trim it's little PCB sides and gently bend the pins  (as seen on Pic)., trimmming with pins facing down
and little holes covered to not get all the nasty dusts on the track...
It won't be possible to use CT all the way as you can see it's pretty tight, but also because the Input one won't pass
at all because the body is too big (about 15.5mm), Jeff's Bourns are 12.5mm ( 5.7mm taken from center) so that would fit better
So the setup that would work would be 1K's from Jeff and 1M from CT....both beeing log and both with 1/8"Shaft for the Api knob lovers haha....
On the pics i didn't used the CT washer, but using it will hide the Pot Thread and so make the knob sit flat on panel...
« Last Edit: January 15, 2012, 07:46:53 AM by zayance »
« Reply #11 on: January 15, 2012, 07:55:34 AM »
Or you could use a trimmer type for the 1M.... torque isn't the same, but it'll fit nicely.
zayance
« Reply #12 on: January 16, 2012, 08:02:29 AM »
901
« Reply #13 on: January 21, 2012, 03:19:11 PM »
Which LED Bar Driver did you guys choose? LM3916? And how to pick RM1 and RM2?
zayance
« Reply #14 on: January 21, 2012, 07:31:57 PM »
Answer is in the Datasheet
http://www.ti.com/lit/ds/symlink/lm3916.pdf
901
« Reply #15 on: January 22, 2012, 07:49:34 AM »
Sorry, for my stupidity, but I have seen the datasheet. But I am missing the part of the schematic that has the LM and I can only guess what Vref should be.
Would you guys care to explain to me? Pleeeeeease....  :-[
« Reply #16 on: January 23, 2012, 08:04:04 AM »
If I could, I would. I'm dyslexic when it comes to datasheets and formulas.
Schematic is the standard two resistor version from the LM390X datasheet.
zayance
« Reply #17 on: February 04, 2012, 03:55:39 PM »
Actually the VCR2N's are also available from Electrochronic, along with some other goodies, a little more expensive than Goldmine elec, but he will ship worlwide, just for info:
https://sites.google.com/site/diypartsstore/catalog/misc-components
901
« Reply #18 on: February 20, 2012, 04:44:16 PM »
I´m 90% done with my build. Still waiting for parts to come in (Grayhills and transformers). I have once again some questions:
The RGB LED I got has 4 pins, which I think is very logical for a 3 color common cathode LED. But there are only 3 holes in the PCB. Should I solder the cathode to ground somehow?
At which point in the circuit is this LED inserted? Or in other words, I´d like to know the maximum voltage that is applied to the LED + RLED so that I can calculate RLED.
I guess there are not that big variations on LED voltages (mine is 1.9V / 3.2V / 3.2V). Maybe any of you who have already completed their builds can tell what they chose?
And whle I´m nearing completion I wonder how to set the 4 trim pots. From the schematic I gather they are Gain for the input stage, for the Limit Mode, Release Time Over-ride (?) and Meter Calibration. But how to dial them in properly?
« Reply #19 on: February 21, 2012, 07:37:42 AM »
1. The RGB LED I got has 4 pins, which I think is very logical for a 3 color common cathode LED. But there are only 3 holes in the PCB. Should I solder the cathode to ground somehow?
2. At which point in the circuit is this LED inserted? Or in other words, I´d like to know the maximum voltage that is applied to the LED + RLED so that I can calculate RLED.
3. And whle I´m nearing completion I wonder how to set the 4 trim pots. From the schematic I gather they are Gain for the input stage, for the Limit Mode, Release Time Over-ride (?) and Meter Calibration. But how to dial them in properly?
1. Can't be common cathode if they are seperate. Get a 3 leg.
2. Max V will be plus 16V.
3. http://www.twin-x.com/groupdiy/albums/userpics/525_Page_10.jpg
http://www.twin-x.com/groupdiy/albums/userpics/525_Page_11.jpg
API 525 compressor
Started by ChrisA « 1 2 ... 9 10 » The Lab
Last post April 15, 2007, 06:19:58 AM
by Tubemooley
Last post April 19, 2005, 11:27:02 PM
by BradAvenson
Last post March 20, 2020, 07:41:34 PM
by duantro
Last post July 02, 2016, 08:01:57 AM
by sharpeleven
