Meathands said:
Ah, I didn't realize you were hoping to run this right into a line input.
Just curious, what would you folks look at doing if you wanted to put something like this between a mic and a preamp for an extra 20dB or so? There is nothing in my limited knowledge that suggests how to do so while maintaining a mic-level output impedance.
I own a Fethead and out of curiosity I tried to verify their statement that noise was immeasurable. In fact I found out that the EIN with a 200R source is about -118.5dBu (22kHz BW), which is not the best performance in absolute, but quite honorable for a 20dB gain stage. What surprised me the most was that noise would increase a lot with source impedance, suggesting that there was significant noise
current, which FET's should not have.
Some discussions suggested that large geometry FET's such as the VLN (1nV/sqrtHz) 2SK170 exhibit significant noise current. The 2SK170 data sheet does not suggest that. Another suggested the circuitry used in the Fethead for biasing the FETs would be the culprit.
Not having the schemo makes all this subject to caution.
In my particular case, I use the Fethead in combination with a chinese ribbon mic that has an impedance of 2.2k (!).
Using the mic directly with any of my regular preamps (Focusrite 430MkII, Avalon 737, UA LA610, LA Classic Channel) results in a less than stellar performance, due to the loading of the mic, which, in addition to losing about 6dB right at the source, chokes the high-mid and treble response, the worse being the buzz due to this rather high impedance signal travelling along 20 meters of cable.
When used in conjunction with the Fethead, the upper response is restaured, and the buzz is gone.
Using Fethead with less idiotic microphones (SM7B, RE20) does not bring significant difference.
My conclusion is that, although the specs are not clearly substantiated with actual measurements, this product does help in some cases.
Two other products were discussed at the time:
The Cloudlifter
http://www.proaudioheaven.com/fr_home.cfm
and this
http://www.fullcompass.com/product/232756.html
