Harpo
Re: GSSL HELP THREAD!!!
« Reply #8240 on: April 26, 2020, 05:34:13 AM »
Hi guys,
I've had a GSSL change in sound over the years, as things do. Less brilliance on the top-end....
I'd suspect ears instead...
Running turbo mod, side chain mod, THAT 2180B vca's. Should I start with the electrolytics?...
... would address the opposite side of the audible spectrum, lacking low end when electrolytics loose capacitance so the hpf rises.
A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools.  -Douglas Adams
alexsaitek
« Reply #8241 on: May 15, 2020, 09:36:07 PM »
Hello everyone, it is my first post :), although I have been looking for information in this forum
First I thank the audiokitchen chef who is a very nice guy and he supplies me the pcb very fast ;)
I have several questions about the construction of this compressor and if someone were so kind to help me
1º Question
I am going to mount that 2181A, the question is, what resistance do I have to mount in the% in the photo that I am going to put? In the main vca I have it more or less clear but in the sidechain vca I don't
(that 2181a data)
https://www.mouser.es/datasheet/2/40...et-1602487.pdf
(web where there are various data)
http://fucanay.fischerworks.com/diy/...S3HsGsqty0DXMc
2º Question
I can't find the 22uf low ESR electrolytic capacitors of 25v and I have seen these 50v ones that seem to be 5mm in diameter the same as the 25v ones, I suppose they will wipe me out?
https://www.mouser.es/ProductDetail/667-EEU-FR1H220
3ºQuestion
Do the resistors come to change the sound a lot? Since I plan to buy from the yageo brand
4ºQuestion
to make the connectors of the main PCB and the auxiliary pcb, would it be worth awg22 cable? in xlr if I am going to put mogami cable that I have here
I leave you here a list of components in case someone is worth a reference, although I do not know if it is completely fine
https://www.mouser.es/ProjectManager...0-5f2cd7ed658a
Thank you and sorry for my English from Google translator. My native language is Spanish.
alexsaitek
« Reply #8242 on: May 15, 2020, 09:44:34 PM »
the new photo that uploaded from the mobile does not look good
alexsaitek
« Reply #8243 on: May 17, 2020, 06:16:14 AM »
hi :)
The 1st question is solved, the resistance in the sidechain vca marked with% is a 47ohm resistance because I am going to use 2181. if I were to use 2180 I would not put any since pin 4 of the 2180 is removed from what I understand
The 2nd question is also solved. You should not have problems to put 50v instead of 25 because they are the same size. I only have the doubt if the brand resistance yageo are good but for now they are the ones that I am going to mount since they are the ones that I have
thank ;)
Last post August 25, 2018, 10:11:21 AM
by musika
Last post September 13, 2005, 06:21:43 PM
by clintrubber
Last post November 09, 2005, 07:52:12 AM
by Soeren_DK
Last post May 03, 2006, 10:57:52 AM
by jensenmann
