Blue Jinn
OK, this may seem silly. I picked up some K47 and C12 clones to try out. AFAIK they are from the same source as the other recent capsule thread.
Got a few single sided and some dual sided. The front and back on the single sided is fairly obvious. On the C12 clones, there is a single negative lead, which is slightly off center line on both the single and dual sided, so I'm assuming the same orientation to "front" and "back" on the dual sided. The K47 clones don't have any obvious difference, except perhaps the hole pattern, but it isn't obvious. So, does the orientation front to back matter? I don't see why it would matter on a dual sided capsule, but if so, how do I tell which is which?????
