Since this type of summing amp flips the signal, it is normally fed into another inverting stage to bring things back into the correct polarity. A transformer is used to eliminate the other active stage needed to rotate the signal and a ratio of 1:1 is selected for sonic transparency, balanced/ unbalanced buss insert drive if needed.
