Majestic12
Re: Majestic12 builds Drip Fairchild 670
« Reply #100 on: January 24, 2013, 03:41:07 PM »
I like the original frontpanel version very much but I see there is a significant difference: on the original version there are only 2 "big" knobs (Gain and Treshold) while on Tat's version there are 3 (Gain, Treshold and Ratio). How can this be applied to Drip's pcb?
The knob labeled "ratio" is just the DC threshold which in the original unit can only be accessed when removing the front panel. Tat decided to put it directly on the frontpanel.
« Reply #101 on: April 26, 2013, 06:26:21 PM »
what's the word on the build? I'm about to embark on the journey!
baadc0de
« Reply #102 on: September 25, 2013, 10:25:51 AM »
Another one done.
But this one is all stepped..
opacheco
« Reply #103 on: September 25, 2013, 11:31:19 AM »
Dear baadc0de,
So nice unit!...Awsome!
Where do you got the chassis case(part number and supplier)??
How about the total cost of the complete unit??
Thanks a lot,
Opacheco.
I love the Vaccum Tubes Sound!!!
Majestic12
« Reply #104 on: September 26, 2013, 04:45:38 AM »
Very nice.
Did you encounter any bigger problems concerning the calibration process ?
« Reply #105 on: September 26, 2013, 09:54:00 PM »
Looks nice...probably sounds nice too, but you're still looking at 3 grand + for the build.
baadc0de
« Reply #106 on: September 27, 2013, 12:35:20 AM »
Very nice.
No, actually I didn't. We had some problems with the M/S matrix, where my colleague who was doing wiring misread the channel number of the in-phase output. So we had some fun with -10dB loss on one channel etc.
The voltages were OK right off the bat and the bias I'm reserving judgement for since it seems that the tubes must really get burned-in before you can make an accurate setting.
Yeah, sounds nice actually. Nobody's sure if it is actually worth its parts, but for me so far as I'm using it it seems to be a pretty smokin' buss compressor and great for vocals too. The different timeconstants are all mostly usable.
Khonnor
« Reply #107 on: December 21, 2013, 10:48:47 AM »
Could I have this file too Thanks a lot!
« Reply #108 on: January 12, 2014, 01:19:06 PM »
Interesting thread!
Does anyone have any hunches as to what metal was used to make the original chassis of the FC670? Is it still available these days?
opacheco
« Reply #109 on: January 12, 2014, 01:46:27 PM »
Interesting thread!
marc11657,
That's info will be great!! but if some one have the engineering drawing of the Original Chassis will be fantastic!!....Does someone knows where could I find this Chassis dimensions and spec.??
Opacheco.
« Reply #110 on: January 13, 2014, 11:04:26 AM »
Interesting thread!
marc11657,
Opacheco.
Indeed Opacheco! I am looking for the drawing of the chassis too, in particular a wiring layout (not the schematic). I have read in the manual that the dimensions are:
Standard 19" rack, 14" panel space, depth behind panel 11"
approx 65 lbs.
Unfortunately I forget who made this or where I found this but there's also a nice design layout of the front panel.
« Reply #111 on: January 16, 2014, 12:36:43 PM »
I've spoken to a few metal experts (not Iron Maiden fans) who have all come back saying the same sort of thing. They believe the metal used for the casing on the 670 is mild steel with a thickness of either 1.5 or 2.0mm. It has been painted with light admiralty grey paint.
Shattersignal
« Reply #112 on: January 22, 2014, 10:19:16 PM »
I'm also curious if anybody has experimented with upgraded caps.  Has anybody gone with Mundorf or Auricap on a Drip 670 build so far?  I'm gathering the transformers and other expensive parts before I commit any solder to this awesome PCB.  Should I consider boutique caps as well?
Producer, Engineer, Score Composer
mdainsd
« Reply #113 on: May 06, 2014, 02:52:06 PM »
Hello all. Long time lurker, first time poster. Also a 670 nut.
In my personal hunt for 670 documentation I seem to find there is almost as much mis-information as information.
The face plate drawing above is a good example. Some controls arent labeled correctly and dimensions left off, i.e. locations of "zero" and "balance" holes.
For sometime I have wanted to do an accurate remake of one for personal use. I commend the efforts of CJ and others who have bitten off this massive task. I wont start with construction until I have reached critical mass on acquiring the critical items to do an authentic remake. This way if I dont get there, I know I can sell the stash of vintage parts Ive accumulated.
Mark
« Reply #114 on: July 16, 2014, 04:34:50 PM »
Mark beside 5 A ,  left , right , vert ect. , how do you mount this face plate ?
« Last Edit: July 17, 2014, 04:56:29 PM by Evertide »
mdainsd
« Reply #115 on: October 13, 2014, 02:08:05 PM »
Where did you come across that picture? (hoping the poster is still around).
That front panel is fairly accurate. It is mounted as follows. There are three through holes on the lower left side of that panel and two on the lower right side. The bottom two hole on each side bolt to a folded steel piece that forms a hinge. The third through hole on the left side (the upper one) is where the power indicator lamp socket is mounted.
« Reply #116 on: October 28, 2014, 06:41:51 PM »
mdainsd,
Did you mean my foto of the  front from the 670 I am building?
mdainsd
« Reply #117 on: October 28, 2014, 07:13:52 PM »
The photo in your post above mine is the one Im referring to. Is that yours?
weiss
« Reply #118 on: October 29, 2014, 05:15:48 PM »
Another one done.
Nice one! how did you illuminate your meter?
looking great
« Reply #119 on: October 30, 2014, 02:48:26 PM »
Yes its mine, I will use the front to build a 670...
Last post October 05, 2009, 12:34:31 PM
by wtmnmf
Last post September 22, 2012, 05:41:51 AM
by DonnieDarko
Last post October 23, 2012, 07:16:04 PM
by illturner
Last post October 03, 2018, 11:34:39 AM
by timkroeger
