moltenwok
Re: Majestic12 builds Drip Fairchild 670
« Reply #20 on: January 06, 2012, 05:23:12 PM »
Just ordered the Sowters for my 660, been chipping away building it as loot permits-I'm using an old UPS case-the DIY panels appear to be labeled differently than the origonal-the meter switch should read Bal-Zero-Bal!   ?
loopermc5
« Reply #21 on: January 06, 2012, 07:09:18 PM »
Have Fun I finished mine a few weeks ago loving it. Be ready to have an empty pocket book.  :(
bieckmusic
« Reply #22 on: January 06, 2012, 07:16:23 PM »
Good Luck, someday I would like to build one of those monsters.  I've mixed through the real thing a few times and it is great great great...
zayance
« Reply #23 on: January 07, 2012, 06:59:03 AM »
Actually looking at the screws on the rack he seem to have racked it so....
whoops said nothing, forgot about the Fpd attachment  ::)
http://www.dripelectronics.com/index.php?option=com_kunena&func=view&catid=13&id=1988&Itemid=41
Majestic12
« Reply #24 on: January 07, 2012, 11:45:56 AM »
BTW...
Somebody just posted in the diy racked forum that there is probably a mistake at the meter select section in the purusha frontpanel....he thinks that the Bal select is missing.
The original unit has Bal - Zero - Bal  the case I have ordered has In - GR - Out
What exactly is ment to be seen on the meter at the different positions in the original unit? I always thought it would be input Signal - Gain Reduction - Output Signal, just like it is written on the new frontpanel...
moltenwok
« Reply #25 on: January 08, 2012, 02:22:58 AM »
To quote page 60 of gregs 660 manual;_
the metering switch has 3 positions
1. BAL : this position will display the balance of the one side of the tube set on the vu meter
2. ZERO : this position will be used to monitor the gain reduction on the vu meter
2. BAL : this position will display the balance of the other side of the tube set on the vu meter
you will use the ‘BAL’ positions in tandem with the ‘cathode balance adjust’
to achieve a proper cathode balance,
but in all reality , it either ‘thumps’ or it doesn’t.
you can actually just adjust the cathode balance till it stops thumping while
compressing , it will be obvious when it is and when it isn’t in thump mode.
your ears and this feature will be very helpful obtaining optimum performance.
zero adj
you will use the zero adjust to place the vu meters needle at zero.
normally you will let the unit warm up for about 15 minutes then
set the meter to zero.
Majestic12
« Reply #26 on: January 12, 2012, 05:25:01 AM »
PCB is here....holy sh*t.....never seen anything like this in my life :D
Well....let's begin:
Drip recommends to first add the spacers on the bottom of the pcb but since I don't have the case yet I started with the tube sockets.
Most of the sockets won't fit the pcb first, you will have to use needle nose plyers to slightly bend the pins towards the center. I also had to use a small file to make some of the pins smaller (just a 10th of a milimeter...) to fit them easily into the holes
You can't mess anything up with the 7 and 9 pole sockets, but you have to make sure that the 8 pole sockets are aligned the right way.
Unfortunately that's it for now. No other parts have arrived yet...
« Last Edit: January 12, 2012, 08:38:59 AM by Majestic12 »
moltenwok
« Reply #27 on: January 12, 2012, 04:56:47 PM »
Nice one bro-have fun-very satisfying!!
loopermc5
« Reply #28 on: January 12, 2012, 10:30:26 PM »
Right it's crazy!!!! that being said little scary hanging it in a rack so I built a little rolly cart for mine to move between our different rooms
take your time and check stuff off as you go I placed 1 jumper not meant to be their gave me and greg a week of headache.
Majestic12
« Reply #29 on: January 13, 2012, 07:20:59 AM »
Well, I think I have put the whole thing in its own rack. It's so deep, it won't fit in anyone of the racks I own....
acoustix
« Reply #30 on: January 22, 2012, 05:37:59 AM »
Just for follow you  ;)
amazing project.
Majestic12
« Reply #31 on: January 22, 2012, 08:52:45 AM »
The cases seem to be ready and will be shipped soon. Can't wait to get mine....
Here are a few pics from diy racked....
Majestic12
« Reply #32 on: January 26, 2012, 01:24:56 PM »
Case arrived today...
Some screws are too long and the time constant pcbs have to be mounted on the side panel....but the case itself is really heavy duty. I'm sure it can take the weight of all the expensive stuff mounted to it :)
zayance
« Reply #33 on: January 26, 2012, 01:36:35 PM »
Looks nice  8)
« Reply #34 on: January 27, 2012, 04:12:23 AM »
hI there
This is going to be a great read, i researched buying a real 670 most of last year, and also the clones out there like the Unfairchild and the Drip and the anamod,
I wish i had the time and the Skill to build one, but i don't.
If anybody is building one of these for somebody and your customer runs into money troubles I'm interested in taking over the project from the position of funding and purchase.
cheers
steve
Majestic12
« Reply #35 on: January 27, 2012, 07:41:15 AM »
BTW....there is only one knob that's worth to be put on a 670.... check out the Fairtressor !
Majestic12
« Reply #36 on: February 06, 2012, 04:45:16 AM »
I just love the look of the frontpanel....
I also got a bunch of parts for the pcb, but had no time to work on it yet.
Aniol1349
« Reply #37 on: February 06, 2012, 07:40:38 AM »
this thing is beautiful! You are one lucky man having that thing in your house!
waiting for more!
Edward
« Reply #38 on: February 09, 2012, 06:40:32 AM »
Where did you get those Dist-ressor type knobs?
I have a project they would fit nice on...
/E
Slenderchap
« Reply #39 on: February 10, 2012, 03:19:47 AM »
I am also interested in those knobs for a friend of mine who is building a Drip 670 ..... if it is something that we can buy in bulk then I would consider making them a stock part.
Colin
www.audiomaintenance.com
Last post October 05, 2009, 12:34:31 PM
by wtmnmf
Last post September 22, 2012, 05:41:51 AM
by DonnieDarko
Last post October 23, 2012, 07:16:04 PM
by illturner
Last post October 03, 2018, 11:34:39 AM
by timkroeger
