JeffTD
Hairball/Mnats Stereo 1176 Meter switches + board help
« on: January 30, 2012, 07:35:27 PM »
I'm in the process of building one of the Hairball/Mnats/Collective Cases Stereo 1176's, but have run into an issue.
I was an idiot and ordered the mouser parts bin for the mono 1176, and as such don't have the proper switching pots for the ratio/meter boards. I found which part # to order for the ratio board, but cannot for the life of me find details on which meter switch to order. Any help would be appreciated!
Also, I cannot find where X/Y are supposed to go from the Meter board. I've followed this guide so far, but I can't locate on my own PCB's where they're referencing X/Y as coming from. http://mnats.net/1176-wiring-rotary.html
Hairball Audio
Re: Hairball/Mnats Stereo 1176 Meter switches + board help
« Reply #1 on: January 30, 2012, 08:31:32 PM »
Hi JeffTD,
For future reference please use the build thread for you're questions.  It helps keep things tidy around here.  Usually the revision build thread is best, but for this question I would post to the stereo build thread:
http://www.groupdiy.com/index.php?topic=44882.0
I've never done the rotary switch build, but something like mouser part #105-13574 should work.  You may want to confirm with the guys in the stereo build thread.
X and Y connect to the VU meter pads.  One of the connections will have a 3.6K resistor in series for +4 metering or an 8.2K resistor for +8 metering.  Which side of the VU X and Y connect to is not important.
Again, if that's confusing check or post in the stereo thread.
Mike
Hairball Audio, LLC
DIY Parts and Kits
https://hairballaudio.com
Top secret stuff and upcoming releases:
http://instagram.com/Hairballaudio
http://facebook.com/hairballaudio
JeffTD
« Reply #2 on: January 31, 2012, 02:04:43 AM »
Ahh thanks Mike, that makes sense.
While I've got you here, though - I'm still slightly confused on the X and Y, considering that there's a specific +/- "meter" pads that I thought were wired to the VU meter pads? Do I just wire X/Y to those and ignore the +/- ports on the meter board, or am I missing something?
Hairball Audio
« Reply #3 on: January 31, 2012, 02:11:55 AM »
Doesn't matter for the meter coil connectors.
Hairball Audio, LLC
DIY Parts and Kits
dandeurloo
« Reply #4 on: January 31, 2012, 12:02:50 PM »
Mike...... WHAT IS LOLA?   Is it your new avatar?
PROFESSIONAL CHASSIS AND FRONT PANELS FOR DIY PROJECTS: WWW.COLLECTIVECASES.COM
Dan Deurloo
www.collectivecases.com
www.risendrums.com
Hairball Audio
« Reply #5 on: January 31, 2012, 03:18:57 PM »
Yes.  Top secret stuff.
Should have an official announcement by friday (hopefully sooner).  Just finishing up the website.
It's going to change your life Dan ;)
Mike
Edit:  Ok check my WM thread.  ;)
« Last Edit: January 31, 2012, 03:31:28 PM by Echo North »
Hairball Audio, LLC
DIY Parts and Kits
Stagefright13
« Reply #6 on: January 31, 2012, 05:39:59 PM »
Lola huh? :)
Oh btw Mnats has a rotary wiring guide on his other compressor file on his site. Was easy enough when I built my stereo one.
John
Amateur experimenter
Last post January 17, 2020, 01:33:12 AM
by Bobby Baird
Last post October 25, 2011, 08:24:22 PM
by Hairball Audio
Last post March 04, 2016, 12:47:57 PM
by Hairball Audio
Last post September 02, 2019, 02:16:59 PM
by Reddbo
