bruno2000
Transformer mounting question
« on: January 31, 2012, 09:34:02 PM »
I have some old 1980s Jensen output transformers that have the typical horseshoe style steel (?) mounting brackets.  There are also holes in the lams for mounting screws (?).  Am I doing something that will damage the transformer if I remove the existing mounting bracket (it's on pretty tight), and just put screws through the holes in the lams to mount the transformer?
Thanks in advance!
Bruno2000
Re: Transformer mounting question
« Reply #1 on: January 31, 2012, 10:56:45 PM »
The channel frame is optional and generally removable. But it depends on how stuck it is, I guess. If the lams are steel you should be OK, but might scrape varnish off and expose the lams to rusting.  If nickel, that's a bit different, it's sensitive to scratching, but it probably won't make a difference either way. If you were to take the lam stack totally apart and restack it, you might end up with a different transformer.  I'd still just try one and measure L before and after.
CJ
Re: Transformer mounting question New
« Reply #2 on: February 01, 2012, 02:58:52 AM »
it should be epoxied together pretty good,
an output transformer should not have 80 supermalloy lams unless it is the weird peerless 217,
if it did have 80 alloy, you would not want to bolt the lams tight as they need to move around a bit,
you might have to take a drill and gently remove the epoxy from the lam holes,
use stainless hardware, non magnetic, if you use steel, it can short the core out a bit at high freqs,
use some Al tie plates against the lams to hold the I sections from falling off,
sounds like you are trying to make a 1U LA2a or something,
just hang it off the back if it won't fit inside the case,
« Last Edit: February 01, 2012, 03:03:30 AM by CJ »
If I can't fix it, I can fix it so nobody else can!
Frank's Tube Page: www.mif.pg.gda.pl/homepages/frank/vs.html
Guitar Amps: http://bmamps.com/Tech_sch.html
Last post October 15, 2004, 06:35:52 PM
by Kev
Last post May 27, 2005, 08:00:21 AM
by netcastle
Last post June 15, 2006, 02:47:35 AM
by JLM Audio
Last post January 08, 2007, 07:18:49 PM
by guy_4
