jeffn9
Blown Fuse On Mesa Dual Rec
« on: February 03, 2012, 01:13:16 PM »
So I blew a fuse on my Mesa Dual Rectifier. I had 4 Mesa branded 6L6s and two 5U4Gs in it. I replaced the 5U4Gs with 2 brand new Mesa 5U4GBs and blew 2 more fuses. I have taken out the 6L6s and shaken them and nothing sounds broken. I can't even turn on the amp without the fuse blowing. I was told it might be a resistor problem. Does anyone have any insight? Thanks!
Re: Blown Fuse On Mesa Dual Rec
« Reply #1 on: February 03, 2012, 01:44:40 PM »
What happen if you remove all the tubes and power up, if not reinstall each tube one by one and see,
D
pucho812
« Reply #2 on: February 03, 2012, 02:56:32 PM »
run it without tubes  and see if it blows up, then turn it off and put in one tube, starting with the rectifiers and turn it on. see if it blows up then. work you way through the rectifiers then to the pre amp tubes, then power tubes.  turn it on and off adding a tube each time the fuse does not blow.
You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is.
Last post February 24, 2006, 08:06:29 PM
by ciminosound
Last post October 03, 2006, 09:55:02 PM
by hagen daaz
Last post December 01, 2007, 11:25:19 AM
by BYacey
Last post August 31, 2010, 06:20:36 AM
by Samuel Groner
