Hairball Stereo 1176 D build
Paprika1
New member
I've been looking for a good wintertime build project, and thought I'd try to tackle the Hairball stereo 1176 rev.D (Collective Cases makes such a nice case for it!) But as I'm a bit new to this game, I'd love to know if anyone out there has a complete BOM for this project. Hairball audio doesn't post one, and there seems to be no direct support for this project on MNATs site.
I get that this project involves basically building two 1176s and a stereo link, but the compression ratio switches on the stereo version are different than on a regular 1176, and Hairball doesn't seem to supply or specify this component...and I'm guessing there are probably other different components too.
A little advice at this stage would be greatly welcomed!
Thanks in advance for all your kind assistance,
Paprika
skal1 said:
Use the Meta my friend.. ere you go...  http://mnats.net/1176_revision_d.html
Thanks! I did find the link to the section in MNATs 1176 wiring guide that talks about wiring a rotary switch. But can you steer me to the right rotary switch to use?
Hi Paprika1
i'm not sure if is what do you looking for, but it can help
http://mnats.net/1176_slam_mode_rotary.html
creal said:
Hi Paprika1
Thanks much Creal! That's just what I was looking for!!
I don't know what the pictured switch is, but I and many other folks are using Lorlins which are listed on many of the available BOMs. I believe the Mnats board set still comes with a ratio switch PCB which will pretty much do all the work for you. You just install the switch, and then link a bunch of numbered pads to matching pads on the main PCB... it's cake. Definitely check if they still come with the board set, because I ordered my board set in '82 or something.
Tim
I was wondering if anyone could post how they wired the toggle switches up for power, bypass, and link/dual I would much appreciate it.  Or if anyone wants to chime in on how to wire it up that would be RADSauce!
There is a thread here already that has a ton of info in it.
http://www.groupdiy.com/index.php?topic=44882.0
The links in the first post will help with most everything.  Skylar did a wiring diagram that will help with most everything.  Compare it against the schematic and it will all start to make sense.  It took me a little bit as well but there is so much info already here.  Lets just try and keep it in that thread to help keep the forum organized.
