(SOLVED) Neumann V475 summing mixer: Frequencies problem!
Aleguitarpro
ITALY
Hi!
I've just finished a 24 input/2 out summing mixer, built with a Neumann V475-2b.
I've remove the mo-12 filter board (and bypassed with jumpers) and I put in each input a 5k1 resistor.
The summing mixer works perfecly with a great stereo image, but I notice by ear a lack in 350-450hz.
So, I've check this with a frequency sweep and a analyzer: is true, those frequencies get lost in the summing...
about 1,5dB of cut, from 350 and 450. Also, from 1.5/2.5 khz I see a light decrease of frequency response, like a very little shelving put from 1.5/2.5khz to 20khz.
The only thing I haven't done, is to recap the Neumann board...
Any ideas?
Here you can listen the tests, with LOGIC PRO internal summing (not a bounce) and with NEUMANN summing mixer:
http://soundcloud.com/aleguitarpro/sets/neumann-summing-mixer-tests
i have no idea what the problem is, but listening to your soundcloud clip on mbp speakers i can't agree with:
you can even see in the waveform preview that there is something really wrong, it sounds totally out of phase and filtered
edit: quick check with a scope....phase totally messed up
SKJGProject is totally right.
my RTW correlation meter goes far to the left, deep red, -1.
listening in mono, no drums left.
phase flipping one side, they are there.
check your wiring. if you are lucky only either the input or the output of one side regarding the V475 is out of phase.
but if your wiring reversed random channels before the summing resistors, or your summing network reverses randomly: have fun ;)
O H    M  Y    G  O  D!
Yes, it's out of phase: I've checked it now.
Ok, thanks! :)
I'll try to check all the wiring, but I'm quite shure they're ok: I've test each of that with a tester, before closing the box.
I've follow neumann's scheme of V475-2b for wiring, but I'll check it again.
Thanks for now!
But, only to know: the old cap on the board could change a freq response? Only in case I'd to do also this thing, however...
Thanks for your help: I've solved my problem.
Now all works correctly: no phase problems, flat frequency response.
The problem was in the wiring: I've used 24 closed jack plug and before wiring I've tested them to wire the resistor board.
After the resistor board I've used 2 balanced cables and 1 channel has a different wire colour... (!!!!)
This was the problem. I've re-checked all the wires and found the mistake.
Here you can listen the beast at work:
http://soundcloud.com/aleguitarpro/sets/neumann-new-summing-tests
The "pushed" file is a sum obtained with an higher value of amplification of the V475 board (+6db), keeping the input channels low. I like very much this result: letting the board working in an higher amplification level, it puts out its attitude in a very beautiful way...
It's difficult to stop listen to!
Thanks, thanks, thanks for help!
No, the only way to regulate the gain (volume) is to put 2 different 2-way switch (one for each channel, with stepped gain and with different value resistor) or one 4-way switch for the stereo gain regulation.
If you take a look at the scheme, you see Rg referred at 2a/2c and 4a/4c pins of first channel and Rg referred at 30a/30c and 32a/32c pins: these are the pins that you have to connect to your switch.
No way to put a pot. Only with stepped gain.
In Neumann scheme you can see, also, that the fixed value for +6db, 0, -12 corresponds to a 13k resistor, short circuit, open circuit.
I used a 6 position 2 way switch to obtain -12, -6, 0, +1, +3, +6 db with different value resistor.
I hope this can help you.
Buanasera, ho un modulo neumann 475, e mi piacerebbe cablarlo, non sono molto esperto e nei pdf che si trovano in giro non ci capisco tanto, gentilmente
riguardo alle resistenze che valore debbo usare ingresso? calcolando 16 ingressi con dei jack a pannello.
Grazie infinite
No, l'unico modo per regolare il guadagno (volume) è mettere 2 diversi interruttori a 2 vie (uno per ogni canale, con guadagno a gradini e con resistore di valore diverso) o un interruttore a 4 vie per la regolazione del guadagno stereo.
Se dai un'occhiata allo schema, vedi Rg riferito ai pin 2a/2c e 4a/4c del primo canale e Rg riferito ai pin 30a/30c e 32a/32c: questi sono i pin che devi collegare al tuo switch .
Non c'è modo di mettere una pentola. Solo con guadagno graduale.
Nello schema di Neumann puoi anche vedere che il valore fisso per +6db, 0, -12 corrisponde a una resistenza da 13k, corto circuito, circuito aperto.
Ho usato un interruttore a 2 vie a 6 posizioni per ottenere -12, -6, 0, +1, +3, +6 db con resistore di valore diverso.
Spero che ciò possa aiutarti.
Grazie infinito
If you've got some auto-translating going on in your browser, be aware that it only works one way (english to the chosen language; it does NOT translate what you write, back into english).
Grazie infinito
Buanasera, I have a neumann 475 V2 module, and I'd like to wire it, I'm not very experienced and I don't understand much in the pdfs that are around, kindly
about the resistances what value should I use input? calculating 16 inputs with panel jacks.
Thank you so much
Hi!
Any ideas?
Hi, what resistors did you use for the volume switches? Can you tell me how you connected them? What type of adder do you have? Neumann, BFE, Protect?
