PEQ-1 - Passive tube eq from my audio labs
atticmike
Howdy fellas,
Has anyone around here given the PEQ-1 a try and compare it to not only to the original but rather to all the other clones?
I'd also find it very useful if you shared the components you put into the project.
Mike
http://www.groupdiy.com/searchresults.php?cx=partner-pub-1749889900964910%3A1545385773&cof=FORID%3A10&ie=UTF-8&q=g-pultec&sa=Search&siteurl=www.groupdiy.com%2Findex.php%3Ftopic%3D10776.0&ref=www.groupdiy.com%2Findex.php%3Fboard%3D14.0
thanks but when comparing both of the parts with each other, the peq-1 by audio labs doesn't really comply with the regular g-pultec caps's values, nor indicates which voltages I'm supposed to choose. I hoped someone around here did the build and procured the parts themselves.
Look a little closer. It's an exact copy.
http://www.gearslutz.com/board/6804865-post14.html
jcpanizza said:
What is the name of our galaxy (2 words)?:
"Milky way".
This is the best help in DIY world that I could give!
p.s. I was interested in the PEQ-1 by audio labs, too, but it's very similar to gpultec (not an exact copy, as others has told you).
In my opinion you can save your money and order pcbs of gpultec here in white market (18 instead of 40).
This is the way I got.
