Hi all
I have got a question... I am just finishing my monitor set up in my very little home studio. The DAW monitor outp[ut runs into my Mackie Big Knob, and from there I can route it to three different monitor outputs
Output A is connected to a small amp powering my DaveTones
And here is where I am in doubt. I am using a small DSP card (mini DSP) to adjust my nearfield A3's a bit and to make the crossover filter for the stallites / subwoofer. The DSP card has Stereo inputs and four outputs. So originally I wanted to use output B to go to the DSP and from there split to the satellites and the subwoofer. But somehow I think it would be cool to use the satellites and subwoofer without each other and / or in combination with the Davetones. So that would mean I have to wire the output C of the Big Knob directly to the subwoofer amp. But that way, I can't use the DSP to control the signal of the sub anymore... Would would be wise here?
Erik
Erik
