kdawg
I'm trying to calibrate the G1176, but I'm a little confused about the volts versus dB info. If it asks for 1 kHz at 0 dB, does this mean a 1 volt peak to peak on my scope hooked up to the signal generator? And +1 dB = ? volts p-p?
And when hooking up the signal generator to the XLR in, should this be between ground (3) and pin 2 since it's unbalanced? Same with the output?
I already seem to have some weird oscillation on the output, but I just turned it on today and haven't begun to measure the voltages. At least the meter driver is OK!
Thanks... should have some build pics up this weekend, getting panels laser engraved.
-kdawg
-kdawg
