I was wondering if you night be able to help me find out more about these Ex-BBC LL88/ASC transformers.
Back in 2008 there's a thread
http://www.groupdiy.com/index.php?topic=24105.20 which states they are ...
Ratio = 1:1
Primary Inductance = 10.6 Henries
Primary Resistance = 40 Ohms
Secondary Resistance = 65 Ohms
On mine the Red/Green winding is 60 Ohms and the Yellow/Blue winding is 34.5 Ohms
The White wire appears to be tapped into the Yellow/Blue winding with 14.5 Ohms between Yellow and White and 20 Ohms between White and Blue.
I've a few questions about it ...
1) What can these transformers be used for?
2) What's the purpose of the White wire?
3) If they're 1:1 transformers, how is it that the windings have different resistances? Is it because they're on concentric windings?
4) Which is the Primary and which is the Secondary winding?
5) What sort of impedance would work in and out of them?
Many thanks.
Ratio = 1:1
Many thanks.
