braeden
Hey guys,
I've got an Illustrator (.ai) file that I've processed in Corel according to the FPE tutorial for the HPGL format but I'm not sure if I've done everything correctly. I can't get the contour lines to show up unless I use simulated fill in the export options for the HPGL format in the advanced tab and apparently this isn't recommended by FPE. Am I meant to be using simulated fill and if so what settings (e.g. cross-hatching/parallel lines, line spacing etc.)
Does anyone have any experience/suggestions or could send me an example HPGL file?
