david-p
I am making a U47 clone with variable polar patterns, using the EQU47 body. This involves several large value resistors in the polarizing circuitry, which I have mounted on a separate piece of perf board above the EF14 tube with point to point wiring.
I am wondering whether I need to take precautions to avoid leakage around the high impedance end of the circuit. Specifically,
-- Should I use glass tubes to feed the capsule connections down through the capsule baseplate?
-- Should I worry about the resistance of the perf board itself?
-- A lot of the Chinese mics use PTFE standoffs on the PCB at the amplifier input. Are these really necessary?
Any thoughts or experiences on this?
Thanks in advance,
David
Thanks in advance,
David
