Cleaning a mackie 1604 Vlz
saxmonster
What is the best way to clean the 1/4 inputs on the mixer?  I am going to use a clean dry paint brush and an air compressor nozzle to clean the top of the board and blow out the 1/4 inputs but what chemical can i use to clean the contacts in the few that make noise or loose the signal?  Deoxit or some kind of spray like that?
-Scott
-Scott
Hi Scott,
try some alkohol like isopropanol with a soft (Q?)-tip,then blow out.
Udo ;)
Ok, I never thought about that!!!!!!!!!!!!  If it cleans solder dirt I guess it will clean regular dirt, haahahah
