Also 68megaohm was used by Neumann.
Ricardus, I wasn't sure if your post was in reply to me, but I'll respond as if it were
I'm about to start this build using the SYT-5 body and Beesneez K8 capsule. Do I remove the capsule from the Beesneez mount to go on the Chinese mount as the Beesneez mount doesn't look as though its going to be compatible with the plastic part between the chassis and capsule mount?Anyone have photos of how this was done if you used the same body and capsule?
I bought the capsule mount from Peluso when I bought the capsules. I took out the plastic thing that came with the body, and mounted the Peluso mount in there. It just required drawing some lines and drilling some holes.
Thank you. So you removed the plastic part at the base altogether?
Did you notice any differences in sound between 2-10mA of Idss?
Started by poctop The Lab
Started by poctop « 1 2 ... 40 41 » Microphones
Started by poctop « 1 2 ... 16 17 » Microphones
Started by Wordsushi Black Market
