U47 FET pcb.
« on: March 14, 2012, 08:22:56 PM »
Have a Skylar body. Well, not his, but the mic one.
Now, working on this:
I want to add polarity patterns like in U87 etc.
Any recommendations for good step-up schemo for 60V polarization for capsule?
« Last Edit: October 14, 2012, 06:51:42 PM by Igor »
http://www.ij-audio.com
(new site hopefully will be up in July)
Marcocet
Re: U47 FET pcb.
« Reply #1 on: March 14, 2012, 10:49:39 PM »
Beat me to it :) I'd already started something similar, but for the 87ish style bodies that are being used for the U1621. Neumann actually made a microphone that was a fet47 circuit in a u87 style body, but I can't find the model number anywhere to bring up a picture.
Oliver at TAB has a transformer spec'd for it that I'd love to check out.
I hadn't gotten as far as stepping up the voltage yet, so I can't be much help on that front. I can't wait to see some suggestions.
EDIT: Found it. The Neumann U497, built in limited numbers for french broadcasting. It was a K47 capsule with U89 style multi-pattern fet electronics built in to a U67/87 style body. I'll start digging for schematic, though I think it's prob a long shot.
« Last Edit: March 15, 2012, 01:07:43 PM by Marcocet »
Re: U47 FET pcb.
« Reply #2 on: March 15, 2012, 12:29:20 PM »
Well-well-well... Bump! Anyone?
Re: U47 FET pcb.
« Reply #3 on: March 15, 2012, 12:34:08 PM »
@Marcocet: saw your comm just now, thanx.
spase
Re: U47 FET pcb.
« Reply #4 on: March 15, 2012, 01:02:23 PM »
Excellent work Igor!
Marcocet
Re: U47 FET pcb.
« Reply #5 on: March 15, 2012, 04:50:15 PM »
Posting the u497 schematic to the gmail account as we speak.
kante1603
Re: U47 FET pcb.
« Reply #6 on: March 15, 2012, 09:08:20 PM »
Cool Igor,
have a nice Thiersch capsule that wants a new home ;D
Udo.
dissonantstring
Re: U47 FET pcb.
« Reply #7 on: March 19, 2012, 01:44:48 PM »
excellent!  looking forward to it.
Moby
Re: U47 FET pcb.
« Reply #8 on: March 22, 2012, 04:39:03 PM »
Looking great mate  ;) as usual. Btw, do you have idea about output transformer?  Be aware of "modern" type of lamination since vintage lams alloy doesn't exist anymore. At least for BV8 ;)
For BV.8,  Bv.11 and Bv.12 transformers contact me at mobyelectronics at gmail dot com
Re: U47 FET pcb.
« Reply #9 on: March 22, 2012, 10:44:21 PM »
me want!!!!!
Adam
only got here by owning a soldering iron and bad life decisions.
craigmorris74
Re: U47 FET pcb.
« Reply #10 on: March 23, 2012, 08:27:16 AM »
Looks great! Would love to have one!
Matador
Re: U47 FET pcb.
« Reply #11 on: March 23, 2012, 05:12:17 PM »
Here's is a capsule bias circuit as explained by Zapnspark:
mad.ax
Re: U47 FET pcb.
« Reply #12 on: March 25, 2012, 07:08:56 PM »
The Neumann U497 was made for French broadcast organisation and used a uncommon 12V power supply... Keep that in mind if you want to modify its circuit for your purpose.
Or you can have a go at the U87A/U89 circuit.
Axel
Marcocet
Re: U47 FET pcb.
« Reply #13 on: March 29, 2012, 06:55:30 PM »
Anybody have any info on the transformer? I know Tab-Funkenwerk makes an exact copy but they're custom order and expensive.
KasperNyhus
Re: U47 FET pcb.
« Reply #14 on: April 01, 2012, 03:24:58 PM »
really interesting project Igor... once again!!! What capsule will suit this project? and will you maybe post a circuit? :)
Moby
Re: U47 FET pcb.
« Reply #15 on: April 01, 2012, 05:21:52 PM »
I'm not sure about winding/ratio but it looks that lams are same as BV8. Also, it looks that shares the same but not 4 chamber bobbin. If that's true I'm sure it's not a big deal (except obsolete lamination alloy/shape). I would like to know about it too since I'm done with BV8  ;)
« Last Edit: April 24, 2012, 11:02:27 AM by Moby »
0dbfs
Re: U47 FET pcb.
« Reply #16 on: April 04, 2012, 05:06:32 PM »
I may be in for a couple PCB's depending on price and accuracy to original ckt.
These mic's are great as FOK mic's and on horns...
jb
Music is everything!
Audio is everything else!
mrc
Re: U47 FET pcb.
« Reply #17 on: April 08, 2012, 10:09:22 PM »
A couple of these would be a nice addition.
Moby
Re: U47 FET pcb.
« Reply #18 on: May 03, 2012, 06:44:07 PM »
Igor, did you find the DC step up solution? I never tried this circuit but maybe it's worth of trying  :o
http://www.instructables.com/id/Simplest-Ever-DC-DC-Boost-12v-to-73v/step3/Connecting-the-power-transistor/
mrc
Re: U47 FET pcb.
« Reply #19 on: May 15, 2012, 08:07:24 PM »
Bump to see how this is progressing, Igor.  I'm really interested in a pair of these...
Last post September 16, 2006, 07:15:50 PM
by tubemonkey35
Last post August 13, 2007, 01:13:34 PM
by Greg
Last post December 08, 2007, 12:08:42 PM
by outoftune
Last post April 10, 2018, 07:24:00 PM
by jeid
