Re: [BUILD] Trident A range PCB support thread
« Reply #20 on: August 29, 2013, 03:22:06 AM »
chaps -
links updated in first post.
Really sorry about my absence, got stuck into many other projects and dropped the ball on this one, but if you ever need any thing please just PM me..
best
Pete
« Reply #21 on: September 13, 2013, 09:17:02 PM »
okay, some probably newbish questions while sourcing parts:
BC550ebc, BC560ebc - I can find no info on or part with "ebc" suffix, is this a part suffix or info for pin orientation? I see on data sheets "A/B/C" suffix for hfe spec, I have picked BC560CTA and BC550CTA, are these sufficient for this build? http://www.mouser.com/Search/ProductDetail.aspx?R=BC550CTAvirtualkey51210000virtualkey512-BC550CTA
http://www.mouser.com/Search/ProductDetail.aspx?R=BC560CTAvirtualkey51210000virtualkey512-BC560CTA
Also, what voltage rating am I looking for for the various capacitor types? The tantalums in particular become significantly more expensive as the voltage rating goes up. I don't want to over spend, but I don't want to burn anything up either.
Thanks for any help. I really need to get better at figuring this stuff out on my own, and should have by now.
I found the link to the mouser project id in the build manual, had skimmed past it before. So I got the cap values, but still need info on bc550/560 as they are not included in the mouser cart.
« Last Edit: September 16, 2013, 07:13:57 AM by adeptusmajor »
dustbro
« Reply #22 on: September 13, 2013, 09:51:25 PM »
I can't find any info on the Carnhill 1198. Is that a typo? Supposed to be the 1148?
kooma
« Reply #23 on: September 17, 2013, 08:08:27 AM »
I think it's just emitter,base,collector-thingy?
What Kind of power transformers are you going to use?
I wouldnt want to use two, so I'm thinking about using just 44V trafo and something to drop few volts,
or 36v and diode pump etc.
Custom made 44v&36V trafo would have costed something like 55€(+shipping etc.)
Indecline
« Reply #24 on: September 17, 2013, 05:50:59 PM »
The build guide says 1148
dane999
« Reply #25 on: September 18, 2013, 07:56:00 AM »
Hi, I built one with the bc550CTA and bc560CTA, and it works fine.
« Reply #26 on: September 18, 2013, 04:39:40 PM »
Cool, thanks guys. I figured the "ebc" probably just stood for "emitter-base-collector", but what the hell do I know... :). looked like a product code the way it was written.
For power - I was probably just going to go with the dual transformer method, unless I come up with something better by then.
« Reply #27 on: September 21, 2013, 08:28:43 AM »
Does anyone have a good source for the 12 pos 2 deck rotary switch? Most options are non-stocked at mouser or digikey, or in stock and ridiculously expensive.
Or maybe does anyone here have a couple of the cheapo Alpha switches or something similar they would be willing to part with?
pH
« Reply #28 on: September 21, 2013, 06:47:42 PM »
I just ordered a pair of Grayhills from Future Electronics ($19 ea.). Allied has an Electroswitch for around the same price. I wanted to get the cheaper Alpha, but in the end I know I'll be happier with the Grayhills.
If people are interested in the Jensen JT-13K7-A inputs maybe we should get a group buy together...
Paul
« Reply #29 on: September 22, 2013, 06:44:58 AM »
Thanks. $19 is definitely more reasonable than what I found.
pH
« Reply #30 on: September 25, 2013, 12:39:50 AM »
Apparently I didn't search well enough, Allied has them for $16 ea.  :P
Hmm, tumbleweeds on this thread so far. I thought with all the new boards in circulation that there would be more activity. Nobody interested in a Jensen group buy?
Indecline
« Reply #31 on: September 25, 2013, 05:20:10 PM »
I'm sticking with Sowter and Carnhills (even though the Sowter's are pretty freakin expensive in the US). It's a cheap build otherwise, especially since I already have a case laying around. I'd like to breadboard the hpf and use the on board insert, but after looking at the 'magic box' I feel that I'm not putting in enought effort!  8)
« Reply #32 on: September 25, 2013, 05:37:30 PM »
Or a Cinemag grp buy
pH
« Reply #33 on: September 25, 2013, 08:20:20 PM »
Daking uses the Jensen, I like the sound of those. I thought I also read somewhere the Trident Audio Developments uses the Jensen as well.
Not stuck on it though. Maybe there's a price break for the Sowter in quantities?
Dylan W
« Reply #34 on: September 27, 2013, 02:31:46 PM »
Is there a reason the gapped VTB1148 is used on the output? Wouldn't an ungapped tx be better since there's a blocking cap on the output? Can you take out the cap if you use a gapped tx?
Dylan
kooma
« Reply #35 on: October 08, 2013, 08:32:06 AM »
about that psu:
Could I use that 2x18V for amp and phantom?
I didnt find info on how much higher input voltage must be to get 48V on tl783..
but if 1.404x36v is~50.5v then shouldnt I be nearly there?? :)
« Reply #36 on: October 13, 2013, 03:59:29 PM »
@ kooma - yes that should be fine.
@all....I have enough for 10 or so pcb's left if any one is still interested.
Just PM me.
Best.
pH
« Reply #37 on: October 13, 2013, 09:51:46 PM »
Just got a channel working, sounds really great. Carnhill output, using a reversed Triad HS-54 for the moment trying to decide which inputs to use. Thanks Pete for the nice boards and the build details. When you doin' the EQ?  ;)
« Reply #38 on: October 14, 2013, 05:57:04 AM »
Ph - please post pics if you can, I would love to see it!
I honestly believe these are some of the best sounding mic pres i've built..and they are not expensive to do either..
I use mine mostly with a SM58, and its in your face lovely!
peterc
« Reply #39 on: October 14, 2013, 08:08:14 AM »
This has become my primary mic pre. I redesigned it to fit in a 500 series frame with  Lundahl input and Jensen output transformers, sounds lovely!
I bought the Sowter input as well but never got around to perfecting that one.......
Good one Peter
If opportunity doesn't knock, build a door.
Last post January 08, 2020, 01:13:55 PM
by Spencerleehorton
Last post November 05, 2011, 07:03:46 PM
by dissonantstring
Last post April 11, 2020, 01:13:11 PM
by Bobby Baird
Last post April 17, 2014, 05:20:15 PM
by SKJGProject
