Re: [BUILD] Tr1dent A range PCB support thread
« Reply #60 on: October 28, 2013, 03:33:50 PM »
guys - i need to think about this...so many would like boards, but im not happy about making lots of boards, Trident are still a going concern, So i might talk to them to see if they mind us doing a version of their EQ before proceeding...
what do you think?
hope thats ok,
Dylan W
« Reply #61 on: October 28, 2013, 05:06:05 PM »
This doesn't seem too different from the DIY projects already available for the Trident 80B eq, the Helios eq, or the Neve discrete eqs, in that they all originated in legacy consoles and are all in some kind of current production by a company (or multiple companies) with rights to the name.
I would be in full agreement regarding a current design by Dave Hill or Dan Kennedy, etc. But IMO, and follow your heart, making a few A Range boards available seems ok. I would also question how much the audience for this DIY project overlaps with people in the market for a $2000/ch eq.
« Last Edit: October 28, 2013, 07:06:21 PM by Dylan W »
« Reply #62 on: November 19, 2013, 09:47:23 PM »
Hi Pete,
I'm interested in your Troodent build and would like to get a couple boards to get started. Can you please let me know if you can provide?
Thanks, Michael
dustbro
« Reply #63 on: November 21, 2013, 03:08:46 PM »
Is this based on a legacy design?
Jim50hertz
« Reply #64 on: November 24, 2013, 03:46:39 AM »
@All.
Also i am making a few A range EQ PCBs for myself and a friend to build, only very small number of boards just for personal use. And i suspect i might include the mic amp too.
If a few of you wanted a board im sure ill have a few spare.
Best
Pete
I'd take four if you get this going Pete  :)
"Nasty, talking to a slightly deaf journalist, had claimed only that the Rutles were bigger than Rod."
spase
« Reply #65 on: November 24, 2013, 02:40:59 PM »
i will take 2-4 :-)
kooma
« Reply #66 on: December 03, 2013, 06:18:02 AM »
in progress: trying part's in to the case.
I ended up adding additional  secondary to my transformer,
so now there should be +50V for phantom board..
buildafriend
« Reply #67 on: December 03, 2013, 09:17:28 PM »
R22 and R21 on the schematic only say "27." By this do you mean 27 K Ohm or 27 Ohm??
Thanks regardless.
« Last Edit: December 04, 2013, 12:30:53 AM by buildafriend »
kooma
« Reply #68 on: December 04, 2013, 04:09:28 PM »
Thanks regardless.
I think they were 27 Ohm, but I just went with the troodent_manual.pdf :)
« Reply #69 on: December 15, 2013, 01:57:03 PM »
very nice work Kooma!
yes 27 ohms...
I think I have 4 boards left, and that is really it, i cant find any more hidden about the place.
Let me know any  one wants them.
Best
Pete
« Reply #70 on: December 26, 2013, 01:46:34 PM »
Hello everyone,
what kind of torodial transformer would I need to power 3 of these pres? I can solder, but I never built anything more than a 51x module.
This would be my first 19" project and I am eager to learn.
Any news on the eq?
Indecline
« Reply #71 on: January 07, 2014, 03:48:30 PM »
Hello everyone,
Any news on the eq?
I'm using a 15va 2x18v, and a 1.6va 2x22v (though I'm not sure if that's the reccommendation for two pre's or just one) I know you can daisy-chain the power together but I'm not sure how much juice this thing sucks down.
As a side note, all my parts should be in by this weekend :D
kooma
« Reply #72 on: January 12, 2014, 05:04:44 AM »
I'm still waiting for my carnhills and a local place to do my frontpanel laser markings,
but psu is working and allmost everything else is ready:)
dane999
« Reply #73 on: January 12, 2014, 11:35:00 AM »
Hi Kooma, could you please give some details about your PSU wiring, how did you add the additional secondary to get the voltages out of one transformer ?
Thank you !
kooma
« Reply #74 on: January 12, 2014, 01:54:27 PM »
Thank you !
I just wound about 10 rounds of wire around the core(on top of the "old"transformer.)
measured what voltage I got and then added more rounds to get desired voltage.
and then paralled old secondaries with the new one and tried wich
polarity gave bigger output and then wound teflon tape on top of the whole thing..
And I epoxied centerpiece to my trafo so It fitted in 1U height.( the plate fastening would have come too fat for my case..)
I had 3 wires coming from trafo; "0", 36vac and "phantomVAC" so I made link wires under psu pcb to link "phantom 0" and "vcc 0".
But before you do this, you should really measure your current transformer output.
Maybe you have bit overvoltage and you dont have to do anything( 36v x 1.404 is~50.5v)
with 2x19vac etc you should be golden.
I actually had bigger output in my transformer, but I thought it would drop under the load...it didnt:)
but as I had allready modified my trafo I just went ahead with it.
Dont know if it's a bad thing to get both voltages(phantom and preamp power) from same xformer,
but since everything has its own regulators I'm expecting it to work ok.
edit: picture as a attachment.
« Last Edit: January 13, 2014, 03:04:28 AM by kooma »
dane999
« Reply #75 on: January 13, 2014, 04:10:04 PM »
Thanks a lot ! I think I'll try with a 2x19VAC transformer. I assume/hope this is not too much for the preamp's PSU.
buildafriend
« Reply #76 on: January 19, 2014, 05:07:34 PM »
hey guys im moving along here and im just wondering what is supposed to go in FFU and what FFU is
thanks regardless
emtee
« Reply #77 on: January 19, 2014, 05:08:30 PM »
For Future Use  ;)
buildafriend
« Reply #78 on: January 19, 2014, 05:10:15 PM »
wow fastest reply ever. so i guess i can leave that unpopulated
emtee
« Reply #79 on: January 19, 2014, 05:11:02 PM »
Yep.
Last post November 02, 2017, 04:38:17 PM
by r2d2
Last post November 05, 2011, 07:03:46 PM
by dissonantstring
Last post August 01, 2018, 08:06:28 PM
by jandoste
Last post April 17, 2014, 05:20:15 PM
by SKJGProject
