pH
Re: [BUILD] Trident A range PCB support thread
« Reply #40 on: October 14, 2013, 06:43:24 PM »
I'll try to get pics once it's a bit more buttoned up, mad alligator clips, flying leads and blue tape removed etc.
I'm kind of surprised at how different this sounds from my other SS pres (Neve and API style). So clear and open on the top. Great stuff.
Peterc - how do you get the higher voltage (44vdc) out of the 500 series power?
peterc
« Reply #41 on: October 15, 2013, 02:11:01 AM »
I didnt...
Just rebiased the output pair to work on +-16v.
Peter
If opportunity doesn't knock, build a door.
dane999
« Reply #42 on: October 16, 2013, 08:55:34 AM »
Hi there, there are some pictures of the troodent A-range I built a few months ago here :
http://pygmeestudio.wordpress.com/2013/07/30/construction-dun-preampli-trident-a-range/
Sowter in, carnhill out, I'm very very pleased with it, 4 more to come soon !
Thank you Grand Master Audio for this amazing sounding preamp !
« Reply #43 on: October 17, 2013, 10:46:38 PM »
I wanted to add an output attenuator to this.... was thinking of throwing a pot between the output transformer primary, signal to wiper. Will this work ok, or is there a better way I should go about this?
Re: [BUILD] Tr1dent A range PCB support thread
« Reply #44 on: October 21, 2013, 02:11:35 AM »
@ adeptusmajor . Im not sure that's an ideal solution.
Essential the 2gang switch pot in the project affects the mic and Line amp stages, you could try separating these two, one control for the mic amp, and the other with more control for the Line amp. If you look at the schematic should make it clear.
« Reply #45 on: October 21, 2013, 02:14:13 AM »
@All.
Also i am making a few A range EQ PCBs for myself and a friend to build, only very small number of boards just for personal use. And i suspect i might include the mic amp too.
If a few of you wanted a board im sure ill have a few spare.
Best
Pete
kpearsall
« Reply #46 on: October 21, 2013, 02:31:50 AM »
Please put me down for at least two!!
« Reply #47 on: October 21, 2013, 07:03:23 AM »
Hi Pete, I am in for a stereo pair!  ;)
« Reply #48 on: October 21, 2013, 07:32:27 AM »
Thanks Pete - I got the idea looking at another preamp I built but wasn't too sure about it. I already have the two gang switches, might just build this thing straight up and try an outboard attenuator to see if it is worth driving harder.
emtee
« Reply #49 on: October 21, 2013, 08:21:29 AM »
Moring all,
Is there a schematic for the PSU sections of this project?
« Reply #50 on: October 21, 2013, 08:49:24 AM »
@ adeptusmajor - go for it, no harm done.
Hi Emtee - Ill have a look when I get home, but do you have the original circuit diagram? if so its identical to that. let me know if you need any further help.
Best
emtee
« Reply #51 on: October 21, 2013, 08:50:59 AM »
Cheers, all I have is the schematic from the pdf build manual.
Mike
bieckmusic
« Reply #52 on: October 21, 2013, 11:20:40 AM »
Hi Pete!
I'd love a pair of the eq boards if you have enough...  that would rock
thanks   :) :)
Greg
« Reply #53 on: October 21, 2013, 01:31:46 PM »
I think I will be in for 3 eq pcbs and some more pres in spring next year, if they will be still available.
jandoste
« Reply #54 on: October 21, 2013, 02:09:14 PM »
2 boards please :)
wow!
dane999
« Reply #55 on: October 21, 2013, 02:57:22 PM »
Hi Pete,
I'm in for 2 eq pcb's if there are some left,
thanks a lot !
museic
« Reply #56 on: October 23, 2013, 10:43:14 AM »
Pete,
I'd also love a pair of the eq boards. Just getting started on the pres!
pH
« Reply #57 on: October 23, 2013, 04:51:44 PM »
Please count me in for a pair as well.
lotus
« Reply #58 on: October 24, 2013, 09:16:15 PM »
Hi Grandmaster, I'd also like a pair of the new boards.Thanks.
Eric
tazwolf
« Reply #59 on: October 26, 2013, 07:07:45 AM »
Hi
I would be interested in 1 EQ pcb.
If there are any left.
Last post November 02, 2017, 04:38:17 PM
by r2d2
Last post November 05, 2011, 07:03:46 PM
by dissonantstring
Last post August 29, 2019, 12:08:09 PM
by Icegoldnixon
Last post April 17, 2014, 05:20:15 PM
by SKJGProject
