Hulk
I'm totally new at this so please be gentle :shock:
I've just started on my first project (SSL clone) and I have started buying parts - I have two questions(after trying to search for info):
a) I have a Resistor Colour Code Calculator so I can convert the colour codes on the resistors to values - Is there anyway to see on the resistor what side/end of the resistor I should start decoding the colour code?? (or will I end up with the same value no matter which end on the resistor I start decoding at??)
b) After testing the resistor does it matter how I place the resistor on the PCB - I know, of course :green: , that the resistor has to be placed in the holes on the PCB specific for that particular resistor - but does it matter how I turn the resistor or is it important that it is placed in the right direction??
Hope you understand what I'm talking about :roll:
