Rob Flinn
Hello,
I'm trying to to find some brass tube 40mm in diameter, with a wall thickness of 1mm length of 167mm to make a skeleton for the interior of a C12 clone I'm making. The actual form I'm after can be described as 2 rings 40mm dia, 1mm wall thickness 9mm deep, with 2 straps between them 10mm x 1mm
The trouble in the UK is that most suppliers only seem to supply the tubing in imperial sizes.
I had thought about getting some 1mm sheet brass & trying to fabricate the tube myself, because most of the tube would be scrap by the time I had finished with it. I'm wondering how easy it would be to fabricate this from accurately from sheet brass. I have a friend who could probably silver solder the bits together.
Basically, I'm just after some ideas of potential suppliers & tips/thoughts about going the fabrication route.
