UTC A11 Input Impedance Switching
idylldon
Idyllwild, CA
Hello everyone,
I'm planning to use an A11 for a tube pre I'm putting together and found this schematic for selecting the input impedance:
http://www.frontiernet.net/~jff/pultec_mb1/images/DualPultecMB1.pdf
It appears that terminals 1+3 are connected together and are connected to two of the terminals on the switch.  The number 2 terminal is separate.  Does that appear correct?
Don
No, connecting any two terminals together would short that part of the winding and quite possibly damage it.  To me it looks like switch position 1 is going to pin 3, position 2 to 2, and position 3 to 1. Which seems to make sense since impedance would increase as you turn the switch.
It is supposed to be two crossovers. Like an LA freeway. Bad idea for drivers. Confusing on drawing.
Cheating with colored pens:
