Hello !!!
You find a lot of different Moving Coil Mic Concepts out there.The Coils may have a dc resistance(in this cases it represents the Outputimpedance of the Coil, I think?.)varies from 10 to 600 ohm ,so a big difference in Coilturns,Wiresize and Weight .A few turns glued on a big Diagramm,10 ohms than feed into a step up Transformer for 200/600 or even 50k output for hify Tape machine mic input(Mics like the Sm58,RE 20 etc have a capsuleimpedance of a few 10 ohms,than feed into a stepuptransformer for 150/200 ohm Output), or much more turns on a small Diagramm with 600 ohm Out, etc .A blank dynamic Mic capsul hold in the Air sounds crappy freq response 100-5kHz with many peaks and dips. so,exssesive mechanical eq like the use of a resonantdisc,ventilation holes, a resonating Grilldesign for the Highboost and flatening,Resonating Tubes in the Body for Bassboost, etc (sometimes 6-7 different resonators-Dampers are build in a single Mic.) is required for more or less flat freq response .The Magnet used is important as well.The stronger the more Output ,but also has a influence in Sound(Modern neodym high output but can sound harsh sometime , very fast attacs,Alnico -lower Output can sound very musical) the size is a factor too. The bigger the Magnet, the bigger- thicker the diagramm,more mass , more output because of the bigger Coil -Magnetic field,theoretical but more damping is required to control the move of the Diagramm ,slower Transientresponse ,when you reach the size of the Soundwave like 10k = 3.4 cm you can create a accustical short on the Diagramm ,greater Soundshadow from behind ,worse off axis behave etc.So it s like most of the time a compromise you get 1 thing better,you discrease the other parameter.
.In the the old days they had 2 way mics with 2 optimised capsule size, with a phase/ corrected L C Network and passive summing (Telefunken M611/811, Akg 221 etc) with Freq ,phase,Transient Response and off axis sound almost like a Condenser.They also don t have a proximity effect because for the Bass they use a pressure and for the mid-high a pressuregradient capsule.Today a Mic like this would cost probably a few $$$$ because it s a lot of aktion to desingn ,to get the Mechanical and electronic Parts together- probably hand mounted -alignment ,needs to be accurate like a Swiss Clock.
Greatings from Berlin
Sorry for my bad written english.
Lothar
