calculating gain in an API type circuit
bigugly
Burbank, CA.
I know this is electronics 101 stuff but the formula I was shown only seems to work for max gain. Here's what I've been using:
[Rf * (Rs1+Rs2)]/[Rf + (Rs1+Rs2)] = X, then 20*Log10(X) = gain in db
When I run the numbers for max gain I get a sensible answer but when I use the numbers for min gain I get nonsense.
example:
Rf = 20000 (feedback resitor)
Rs1 = 200 (shunt resitor)
Rs2 = 20000 (rev log pot)
so at max gain Rs2 is shorted so my math is this:
[20000 * 200]/(20000 + 200) = 4000000/20200 = 198
20*Log10(198) = 45.9db of gain
min gain is:
[20000 * (20000+200)]/[20000 + (20000=200)] = 404000000/40200 = 10049
20*Log10(10049) = 80db of gain!
so i guess it's fairly obvious that I'm doing something wrong here.
Please help me. Of all the reading material I have, nothing covers this
James Lee
Big Ugly Van Audio
Hey James,
I've been here before. Check this thread:
http://www.groupdiy.com/index.php?topic=1085&postdays=0&postorder=asc&highlight=algebra&start=15
Specifically, look for PRR's reply, as he simplifies things a bit.
Regards
ju
It's fairly straight forward:
Av=Rf/Rin+1 or in you're case Av= R3/(R2+R1) +1
Gain in dB= 20logAv
So, if you're using the typical 312 schematic the low and high gains would be:
Av= 20,000/(20,000+200) +1 = 1.99
Gain in dB = 20log(1.99) = 5.97dB
and
Av= 20,000/200 + 1 = 101
Gain in dB = 20log(101) = 40.09dB
Then if you're using the a 1:10 input transformer this would add an additional 20dB of gain at all settings. If you wire your output transformer for 1:2 it would add another 6dB to all settings.
If you're using an inverting amplifier, just drop the +1 from the equation.
Hope this helps,
Jeff
So, based on all this, I think it´s true to say:
Rgain = (R3 / gain-1) - R2
Rgain = resistor in ohms
gain = Vin/Vout
Yes. But remember an inverting amplifier's gain will not be much less than 2.
I recommend using a 25k reverse log taper gain pot (if you can find one). Rf should then be a 25.5k 1% metal film bypased with a 47pf polystyrene or polypropylene cap. Then R2 should be 470 ohm. This will translate to about 35dB maximum gain and a low gain of 6dB.
Many combinations are possible depending on the availabilty of the gain pot value you can get. Use Pspice or the trusty calculator to set the value of your feedback capacitor. A 1us R*C is a good place to be.
regards,
Jeff
