Re: [BUILD] LC53A~500 Series~Love Child EQ Kit~Official Support Thread
« Reply #360 on: July 13, 2015, 07:33:05 AM »
I'm using these eq:s in a console that already has HP filters and i would like to try and change the one ine the EQ to 300Hz. Also i would like to try and change the LP to 12k. I'm not sure which caps are setting the cutoff FREQ. Can you point me in the right direction Jeff? Also if might need to adjust my new cutoff to taste so a set of numbers to calculate that would be appreciated,
Emil
jsteiger
« Reply #361 on: July 13, 2015, 11:16:13 AM »
Hi Emil
C9/R13 and C10/R2 are for the HPF
R7/C4 and R5/C5 are for the LPF.
You can use the calculators here to find your new values. http://sim.okawa-denshi.jp/en/CRhikeisan.htm
IIRC, I followed the bandpass filter from the 550A
Visit the CAPI store at http://www.capi-gear.com
CAPI is not affiliated with, endorsed by, or sponsored by API.
Re: [BUILD] CAPI LC53A~500 Series~Love Child EQ Kit~Official Support Thread
« Reply #362 on: November 19, 2015, 07:19:39 PM »
Dear Jeff and everybody,
built my first one of two, with red dots in.
Everything works right except for a couple of positions:
5k HF peaking seem centered on a 9k area with a sharper q than the other settings.
seems shelving works ok.
400 LF both peaking and shelving doesn't work at all.
any clue for me?
thanks
Raffa
jsteiger
« Reply #363 on: November 19, 2015, 08:12:11 PM »
Raffa, which 5k. Mid band or high band?
This is a little odd because they are actually completely unrelated. I mean that they do not share any common circuitry. Could it be a bad solder joint(s) problem?
« Reply #364 on: November 19, 2015, 08:25:02 PM »
Hello Jeff, thanks for the quick reply:
5K high frequency in peaking mode. In shelving seems to be working fine.
Regarding 400... It can be, even if my soldering skills are really improved in the last month.
The only thing shelving and peaking has in common is the frequency selector. I'll start double checking that. Any other clue?
Raffa
jsteiger
« Reply #365 on: November 19, 2015, 09:34:58 PM »
So it is the high band control? I asked since 5k peak is also available on the mid band control. After the switch, 5k peak on the high band is C31 in parallel with C32 and then to inductor L4. Since .075H and .0047µF give us 8.5k, my guess is there's a bad solder joint on C31 (.01µF) or its failed open which can be measured if you desolder it. Its prolly a bad solder joint though. I would reflow C31 first.
Well, the switch is a 2 pole switch. One side for peak and one side for shelving so even though they share the same switch they are not electronically related inside of it. 400 peak on the low band is R10 to C10 to the L2 inductor. I'd reflow those points. 400 shelving is R5 to L1. C9 is the common cap that is between L1 and ground so if the other low shelving bands are fine, it won't be C9.
It probably won't be the inductor(s) for either 400 problem since that tap is closest to the common so if the rest of the pins are OK, chances are that one is too.
« Reply #366 on: November 20, 2015, 03:57:25 AM »
Solved everything! :)
tried it on some real audio... wow.
Great!!
Raffaele
« Last Edit: November 21, 2015, 12:35:56 PM by kokkobil3 »
Golgoth
« Reply #367 on: January 05, 2016, 07:37:09 AM »
What is the most popular opamp combo on this one?
jsteiger
« Reply #368 on: January 05, 2016, 08:41:01 PM »
Folks order then all different ways. I don't think there is really a bad choice. Not sure if that is helpful or not.
Golgoth
« Reply #369 on: January 06, 2016, 04:02:36 AM »
It doesn't really help but it confirms I'm going to go for 2520/1731 like in my 28  ;D
Thanks Jeff
rabe
« Reply #370 on: January 12, 2016, 08:02:20 PM »
Hi Jeff,
I botched the building of a DT05 for my LC53A kit.  Is there a way I can purchase just a DT05?
Rob
jsteiger
« Reply #371 on: January 12, 2016, 08:40:55 PM »
Yeah man. Just send me an email thru the store.
rabe
« Reply #372 on: January 13, 2016, 03:31:47 PM »
Thanks!!!
Golgoth
« Reply #373 on: January 26, 2016, 01:02:48 PM »
I am currently gathering tools and informations for my future 53A build. I’d like to get some answers to the questions I have before starting, especially regarding calibration (I hate trimmers!!!).
- First of all my audio installation has -6db inputs. Is it ok to add a plugin to my DAW’s input track before monitoring anything to get unity? I assume it is.
- I will be using the extension test jig and not a special cable, where should I take the measurements to adjust the generator’s output to 1 volt AC?
- Do I really need to monitor the output with both my DAW and a MM? Finding the lowest possible dBu value on the computer screen should be enough, right?
Having two different methods available for calibration got me confused I think…
>>> To the people in Europe and especially France where the Hakko CHP-170 is impossible to find, the Plato 170 is the exact same cutters and is easily findable for 5€ from UE sellers on eBay!
I hope the kit is back in stock soon, I can't wait to get started!  ;D
jsteiger
« Reply #374 on: January 26, 2016, 02:22:57 PM »
I am actually in the midst of building/testing a new updated board layout for LC53A. I had to change some silkscreen things (remove the small arrow) so figured I would make a few layout improvements. One of those things was to change the receiver stage in a way that CMRR cal is no longer required. As soon as I get the build finished and tested, I will post the stock. Hopefully over the next few days. I also made the mounting of the follower's and DTO5's a bit easier.
Golgoth
« Reply #375 on: January 26, 2016, 02:39:26 PM »
That's amazing news Jeff! Will the building process differ a lot from the old version? Chunger's guides are always so helpful...
jsteiger
« Reply #376 on: January 26, 2016, 03:51:57 PM »
A few details but mainly on the small end. His work is 2nd to none  :)
Golgoth
« Reply #377 on: January 26, 2016, 04:04:13 PM »
VITAL for beginners like me.
« Reply #378 on: January 30, 2016, 09:46:01 PM »
Can't wait for the stock to come in. I need to build another to make it a stereo pair. I need to change the faceplate knobs on my old one too I guess. It's all about the front panel right? :)
Will the new "version" sound at all different? Hoping to get the two as similar as possible. I suppose it might just be a noise floor difference.
jsteiger
« Reply #379 on: January 30, 2016, 10:03:24 PM »
Yes, front panel and knobs. I have Nip-N-Tuck kits posted for all old modules now http://capi-gear.com/catalog/index.php?cPath=209
No, there should be no noticeable difference in sound or function. The noise floor will be the same. Should be nothing to worry about really  ;) I am literally just about to test all of the frequency controls and filters.
Last post June 19, 2020, 08:55:58 PM
by zonkola
Last post April 24, 2019, 06:18:12 PM
by Mrosso
Last post July 23, 2019, 01:04:02 AM
by boji
Last post May 24, 2020, 02:35:00 PM
by jsteiger
