bruno2000
Trident A-Range "Channel Strip"
« on: April 25, 2012, 11:05:19 AM »
Greetings Folks,
Here's the latest addition to my "700 Series" projects.  A Trident A-Range mic pre and EQ.  The input transformer is a Sowter, the inductors are from ChrioN, and the output transformer is an old Jensen.  Special thanks to Dan for his help in de-ciphering some very old drawings.  These are true to the original circuit, with some minor gain structure changes, and the addition of one frequency per band.  There may be some partial kits available, and if/when that happens, I'll post in the white market.
Bruno2000
« Last Edit: April 25, 2012, 11:17:09 AM by bruno2000 »
bruno2000
Re: Trident A-Range "Channel Strip"
« Reply #1 on: April 25, 2012, 11:15:44 AM »
Reserved
Indecline
« Reply #2 on: April 25, 2012, 11:22:12 AM »
wow! awesome job!!  8)
is there line input on this puppy?
bruno2000
« Reply #3 on: April 25, 2012, 11:48:21 AM »
No line input as such.   Seems nobody makes a quality 20-24 position 90 degree PC mount switch that would be necessary.  My solution to the line input is to engage the pad, and feed the line level signal into the mic input.  You could always modify the pad for whatever input impedance and loss you wanted.
Bruno2000
noulou
« Reply #4 on: April 25, 2012, 02:56:11 PM »
 :-X
Joechris
« Reply #5 on: April 25, 2012, 04:43:28 PM »
Speeachless!! I want one. Do you power these with 40V? What is the front size of the 700 series?
musicians vary +/-9dB depending on mood, drugs, and line-voltage. (PRR)
bruno2000
« Reply #6 on: April 25, 2012, 05:03:52 PM »
I have been using the 51X power transformer and regulator board to power all of my "700 Series" builds. They put out +/- 16V +/- 24V, and +48V for Phantom Power.  To that, I add a small +24V supply for the relays.
The rail Voltages for the Tridents are 44V and 24V, obtained by using the -24V supply as "ground" within the board, then regulating the addition of the +24V down to 44V for the output stages.
The panels are 2" wide x 7" high, so you can easily fit 8 of them in a standard 4U card cage.
Bruno2000
leadbreath
« Reply #7 on: April 26, 2012, 03:36:43 AM »
shweet, when can i order mine??? :)
f**k marlbro's and weed ill stick to smoking germanium and silicon
canidoit
« Reply #8 on: April 27, 2012, 08:31:24 PM »
Bruno,
Curious, I have never heard of the 700 series? Is this a new system or old system? Where do you find the enclosures for them??
iva dunit formerly known as canidoit
bruno2000
« Reply #9 on: April 30, 2012, 10:38:32 AM »
The story of the 700 series goes like this.  A friend and I were dumpster diving when we came upon these 2 card cages that we think held some dbx 310D noise reduction modules.  At that time, I wanted to build some compact Neve clones to go into my Remote Truck.  These card cages seemed to lend themselves very well to my project.  They were deeper and taller than the 500 series, so I could use a larger circuit board, there were more "fingers" available for power and I/O, and the front panels were 2"x7" rather than 1.5"x 5.25" so there was more room for controls.  So far my projects in this format have been mic pres and full EQs in this compact package.  Now, admittedly, I've got a bunch of stuff crammed into a small space, but that's my Remote Truck mentality.
http://www.groupdiy.com/index.php?topic=40610.msg503046
Once I had these done, why not build some other "Vintage" clones to fill up the empty spaces?  So, I started working on the APIs,
http://www.groupdiy.com/index.php?topic=46630.msg586579#msg586579
 and then the Tridents.  I'm working on some other modules as well.
I am not sure who made these cages I found (all of the hardware is metric), but I have seen empty 4U card cages on eBay for not very much money.  I have another friend who "converted" a dbx 216 rack to accept these modules as well.  There are probably quite a few unused dbx 216 racks out there collecting dust.
There' s no reason one could not spread the front panels out a little with outboard switches and pots, in fact, a forum member is doing just that right now.
Understand that this was NOT a commercial endeavor, and I am not trying to establish a new standard.  I pretty much just build things to use myself, but if someone else wants to give it a go, that's OK with me.
Bruno2000
leadbreath
« Reply #10 on: May 21, 2012, 04:03:45 PM »
hi
just wondering about any new developments on this unit? im really keen on one of these..
mick
bruno2000
« Reply #11 on: May 21, 2012, 04:29:01 PM »
hi
mick
Just PM'ed you.
Bruno2000
« Reply #12 on: May 22, 2012, 11:17:11 PM »
I'm waiting to lay two sideways in a 1ru rack
dustbro
« Reply #13 on: July 06, 2012, 03:52:10 PM »
Great job man!
bruno2000
« Reply #14 on: July 10, 2012, 04:10:25 PM »
I am about to do another run of these boards.  Anyone interested, please PM me.
Bruno2000
leadbreath
« Reply #15 on: July 10, 2012, 06:07:24 PM »
hey
im def. interested in a pcb set, depending of price.
pm sent
much appreciated
mick
kpearsall
« Reply #16 on: July 11, 2012, 11:00:54 PM »
Is there a BOM for this?
SubhumanRecords
« Reply #17 on: July 12, 2012, 09:45:36 AM »
Hey all,I would say brunno2K is busy,but yes there is a BOM.If Brunno don't care or have time I can email it to.
Marc Duchesne
« Reply #18 on: July 13, 2012, 09:28:20 PM »
PM sent for a couple ... :-)
« Reply #19 on: July 14, 2012, 07:42:02 AM »
I have a question about the knobs you use one the Grayhill switches. The ident on some has a position dead vertical and others at plus or minus 15 degrees from the vertical. By default, the Grayhills with their D shaped spindles end up with most switches pointing plus or minus 15 degrees to the vertical. How did you get the vertically aligned ident ones to work?
Last post August 26, 2011, 10:01:12 AM
by njm
Last post September 16, 2008, 06:47:06 AM
by RedNoise
Last post January 04, 2012, 11:39:37 PM
by mauibound
Last post October 05, 2020, 08:34:07 PM
by pucho812
