voitto
Re: Make Cheap but quality Stepped pot
« Reply #40 on: March 09, 2015, 12:33:36 PM »
I've found that by removing the spindle, compressing the spring a bit and greasing the ball bearings  with lithium grease It gives the switch a much smoother lighter action.
Also -  filing the edges of the hole that the ball pushes into with a Dremel helps the switch hit the right spot each time.
Ive just modified 8 of them without problems. If you compress the spring by the right amount they can feel really quite nice!
« Last Edit: March 09, 2015, 12:37:22 PM by voitto »
Jim50hertz
« Reply #41 on: January 26, 2019, 01:08:14 AM »
Link to the switch is dead..,,
Can anyone point me in the right direction?
Need a couple of switched pots for a great river mp2  build and this looks ideal
"Nasty, talking to a slightly deaf journalist, had claimed only that the Rutles were bigger than Rod."
scott2000
« Reply #42 on: January 26, 2019, 01:32:32 AM »
« Reply #43 on: May 22, 2020, 04:55:44 AM »
Hey Zayance if you could re-upload the pictorial that would be great  8)
peterc
« Reply #44 on: May 22, 2020, 07:57:08 AM »
That would be excellent! Missed this thread originally......
If opportunity doesn't knock, build a door.
Last post September 13, 2009, 06:04:18 AM
by bongolijus
Last post October 28, 2011, 10:54:14 AM
by radiance
Last post September 28, 2011, 11:55:24 AM
by geoff004
Last post February 05, 2020, 08:59:23 AM
by JohnRoberts
