rkn80
Photostory: Building a AES -> ADAT bridge
« on: May 12, 2012, 01:14:05 PM »
here I present you a photo story about building a 32 channel AES to ADAT bridge.
This project is a spin-off of the Modular AD/DA box project. The PCBs used here can also be used together with the earlier PCBS of the AD/DA box.
The bridge works quite simple: It converts 16 AES stereo streams (32 mono channels) into 4 ADAT lightpipe streams (each with 8 mono channels).  Nothing more, nothing less. Every building step will be documented here.
So now let's start!
Raphael
rkn80
Re: Photostory: Building a AES -> ADAT bridge
« Reply #1 on: May 12, 2012, 01:16:53 PM »
These are the two PCBs we need to stuff with components:
« Last Edit: May 27, 2012, 06:18:57 PM by rkn80 »
rkn80
« Reply #2 on: May 12, 2012, 01:20:35 PM »
First the ADAT light pipe transmitter PCB.
rkn80
« Reply #3 on: May 12, 2012, 01:21:44 PM »
All ICs mounted.
rkn80
« Reply #4 on: May 12, 2012, 01:24:59 PM »
All 0805 components mounted.
rkn80
« Reply #5 on: May 12, 2012, 01:26:01 PM »
Tantal cap's mounted.
rkn80
« Reply #6 on: May 12, 2012, 01:27:15 PM »
Toslinks mounted.
To be continued...
gyraf
« Reply #7 on: May 13, 2012, 05:43:36 AM »
Shouldn't this be in "Higher order"?
Jakob E.
rkn80
« Reply #8 on: May 13, 2012, 08:25:38 AM »
No I don't think so. Because it is simple pick&place like in the analog project world. ;)
rkn80
« Reply #9 on: May 13, 2012, 08:26:40 AM »
Continued with the AES input. First all receivers are mounted.
rkn80
« Reply #10 on: May 13, 2012, 08:29:45 AM »
And all other ICs.
To be continued...
s2udio
« Reply #11 on: May 13, 2012, 03:53:25 PM »
Jakob E.
+1 Not really analogue ,def should be HO
Quite interesting though...Just been thinking about something like this,...looks a similar design to the  behringer ADAT 1616 X 2
Afraid i don't have access to a pick n place machine  ;D
Any schematics ?
« Last Edit: May 13, 2012, 04:04:35 PM by s2udio »
On the end of a Rural Twisted Pair.
gemini86
« Reply #12 on: May 13, 2012, 05:53:15 PM »
He didn't say pick and place machine, just pick and place... you're the machine. 0805 components are very much doable by hand.
- Rodney
"...you better call Kenny Loggins, 'cause you're in the danger zone."
living sounds
« Reply #13 on: May 13, 2012, 06:02:36 PM »
Looks very interesting! Are there any parts that need programming involved? Is there a schematic (or even a PCB for a DIY project)? Are higher sample rates supported?
I could use a 4-channel version of these... ;-)
keefaz
« Reply #14 on: May 13, 2012, 08:00:30 PM »
I find some 0805 resistors pads are very close to ICs on the pictures, surelly need a steady hand when soldering at those places
s2udio
« Reply #15 on: May 15, 2012, 05:56:48 AM »
Yes quite aware of that , just joshing.... :)
......any pcb is "pick up- part" and "place - part" not just smt comps!
« Last Edit: May 15, 2012, 06:00:06 AM by s2udio »
rkn80
« Reply #16 on: May 16, 2012, 10:11:53 AM »
Now all 0805-Caps are installed.
Regarding schematics, I'll upload them at the end of the story. But there is nothing special. In fact I just copied the applications circuits from the data sheets and put them together.
R.
« Last Edit: May 27, 2012, 06:19:53 PM by rkn80 »
Lowfreq
« Reply #17 on: May 17, 2012, 06:30:38 AM »
Are you still making the straight ADAT boards? Or is this replacing them?
Also, would this replace the separate AES boards from the AD/DA project?
rkn80
« Reply #18 on: May 25, 2012, 06:27:13 PM »
Hm, I do not really understand you. What do you mean with straight ADAT boards?
The AESin board is not replacing the 4 channel boards. In fact I copied the circuit from there and made this bigger board with 16 AES stream (32 mono channels) because I did not have enough boards left from the group buy so I had to order boards anyway and therefore I can put then more channels together on one board. Btw. both boards are compatible with the pinout of the delayed main board.
R.
« Last Edit: May 25, 2012, 06:30:32 PM by rkn80 »
Lowfreq
« Reply #19 on: May 25, 2012, 09:34:39 PM »
What I mean is, can you use the adat pcb without the AES boards.
Last post June 10, 2004, 12:02:49 PM
by OldHouseScott
Last post October 18, 2015, 03:09:03 AM
by gyraf
Last post May 01, 2011, 05:48:44 PM
by Adky
Last post October 13, 2014, 10:11:00 AM
by mrclunk
