Rob Flinn
I need to tap some M1.6 threads for my C12 project. What size should I drill the hole ? I'm thinking 1mm is going to be tough work for the tap, & 1.5mm will mean that the threads aren't deep enough.
to be really anal about it, the pitch is the distance between the threads and not the depth, if threads were 45 degree angle each way, then your method would work, but they are not. dont ya love smart arse ex mechanical engineers!Timothytitus88 said:My understanding is that you need to take the thread pitch from the diameter.
Heck yesssssss, cos I am one myself.dont ya love smart arse ex mechanical engineers!
Rob Flinn said:I need to tap some M1.6 threads for my C12 project. What size should I drill the hole ? I'm thinking 1mm is going to be tough work for the tap, & 1.5mm will mean that the threads aren't deep enough.
It happens that threads are at 60°, and thus the pitch is the same as the depth. At 45°, the depth would be 0.707 times the pitch.Junction said:to be really anal about it, the pitch is the distance between the threads and not the depth, if threads were 45 degree angle each way, then your method would work, but they are not. dont ya love smart arse ex mechanical engineers!
Cheers from the east coast of Oz
Junction said:....And if you were not reversing up regularly when u were tapping holes, then it is not wonder you have broken a lot of taps in your time ... they can get bound up with all the swarf when tapping.
Junction said:And if you were not reversing up regularly when u were tapping holes, then it is not wonder you have broken a lot of taps in your time ... they can get bound up with all the swarf when tapping.
In one of my first jobs, we bought a tapping contraption that was installed in the dril press. There was an automatic reverse; whenever you stopped pressing, the tap would reverse at low speed. Apparently, this doesn't exist anymore; it seems it's much cheaper buying an automatic tap machine...Junction said:Rob, its been like 20 years since I have been tapping holes for a living, but trying to visualise in my head, but turn that sucker in 1 turn clockwise and then back it off anti-clockwise half a turn to break off the swarf and then continue like that all the way through, 1 turn forward, 1/2 a turn back. If you just try to plough through without the forward/ back approach, thats when you will either break the tap or tear up the thread.
Maybe one of you other "ginger beers" would like to comment, but this forward/back process is the way to go.
Michael
abbey road d enfer said:In one of my first jobs, we bought a tapping contraption that was installed in the dril press. There was an automatic reverse; whenever you stopped pressing, the tap would reverse at low speed. Apparently, this doesn't exist anymore; it seems it's much cheaper buying an automatic tap machine...
