rkn80
High-End DAC for modular AD/DA box?
« on: June 07, 2012, 04:31:08 PM »
I got several request wether I'll ever make an high-end module for the AD/DA box perhaps using the PCM1794 or similar like AVID. Therefore, the intention of this thread is to evaluate wether there is really interest not wether or how it can be done.
R.
Lowfreq
Re: High-End DAC for modular AD/DA box?
« Reply #1 on: June 08, 2012, 07:10:06 AM »
I'd be interested.
michal_k
« Reply #2 on: June 08, 2012, 09:39:24 AM »
I'd be interested in a 2 channel board. Also, it would be cool to make I/V stage on a separate plug-in board so that folks can choose between ic and discrete designs.
And there's that:
http://www.twistedpearaudio.com/digital/cod.aspx
« Last Edit: June 08, 2012, 11:04:03 AM by michal_k »
« Reply #3 on: June 08, 2012, 02:48:20 PM »
I don't know that I have a real need for one, but I'd love to help with the design.  If the project gets underway maybe I could be of service.
« Reply #4 on: June 08, 2012, 03:42:06 PM »
i'd be interested, but only if/once ethernet connectivity is achieved.
There's nothing like the right tool for the job.
And -usually- that's what I end up using...
..nothing like the right tool for the job!
« Reply #5 on: June 09, 2012, 03:29:18 AM »
100% interested. I have been looking for exactly this for a long time. and if it fits into the modular set up that would be amazing.
I am looking for 8 -16 channels of high quality DAC.
AES is the format for me.
rx
« Reply #6 on: June 12, 2012, 06:25:29 PM »
I am very interested, if based on PCM1794A (and 100% pin compatible pcm1798, if some want cheaper alternative ).
I think making boards with several same stereo dac chips would be more interesting to offer some added "pro approach" compared to stereo COD module : each board of 4 or 8 pcm1794 would be a good unit (with dual mono option).
Also each PCM input pad need to have a close ground pad (reduce EMI)...
I would also be OK for any other 5v level input signal (optorec) compatible Right justified 24 hiend dac chip such as WM8740 (or AK4393 or some other newer AKM) which are great too.
I have just discovered your whole project and I am very interested in it.
Having one optorec receiver circuit onboard would be even better in my opinion ! so as to offer near complete multichannel playback board.
usekgb
« Reply #7 on: June 12, 2012, 08:05:12 PM »
Totally interested.  I need 16-24 ch of high quality DA/AD.  Has anyone cracked the Ethernet interface issue yet?  Also, what would clocking look like?
Zach
Zach Griffen Audio
EvilTone
Nele
« Reply #8 on: June 13, 2012, 06:36:59 AM »
How about the ES9023? I've just ordered two boards at diyaudio.com.. seems to be nice.
mik
« Reply #9 on: June 13, 2012, 06:24:10 PM »
And there's that:
+1 I want to use tube.
jandoste
« Reply #10 on: June 28, 2012, 06:52:05 PM »
+1
« Reply #11 on: June 29, 2012, 02:33:06 AM »
Lets keep it modular so people can add their own output stage - tube, IC, transistor.
john12ax7
« Reply #12 on: June 29, 2012, 10:45:37 AM »
I might be interested depending on details and cost.
Last post May 13, 2008, 12:45:40 AM
by
Last post August 25, 2009, 04:48:10 PM
by pstamler
Last post January 31, 2010, 10:02:30 AM
by Moby
Last post November 28, 2010, 07:28:43 PM
by okgb
