Decent Knobs for Grayhill 71 Series Switches
Norfolk - UK
I am struggling to find some decent knobs that will fit a Grayhill 71 series rotary switch - the type with the quarter inch D shaped shaft. I really would like a push on type with a separate top insert with a line so I can have different coloured knobs and easily align the knob position with the panel legend. Sifam do exactly what I want BUT they only do it in a 6mm shaft, and despite trying to apply a file to one I cannot get it to fit a 71 Series shaft.
Here's a link to the Sifam part:
http://www.rapidonline.com/Tools-Equipment/Sifam-15mm-Splined-and-D-Shaft-Push-Fit-Control-Knobs-502502/?sid=b3070f8f-45cc-4b40-95ce-a5e21bd6954f
Any ideas??
I've ordered Sifam knobs from Selco, which is a supplier in the USA. They list a push-on knob for a 1/4" D shaft:
http://catalog.selcoproducts.com/viewitems/conventional-push-on-knobs/standard-basic-knobs?
I'm not sure however if these have a separate top insert. The collet type do, which is what I've ordered in the past.
You know, those look awfully like Sifam knobs - even the part numbers look right -instead of 06 on the end for 6mm they have 250 for quarter inch. So why don't they show up in Sifams web page?
P.S. I should have mentioned I am looking for 15mm diameter knobs.
Thanks for the tip.
I have been using OKW knobs. http://www.okwenclosures.com/products/okw/comb-knobs.htm They are collet knobs so not perfect for a D shaft but close enough in my book. I have been toying with the idea a small plastic inserts from rod stock for better grip.
Here in the States the distributor only has a 10pcs minimum which is very nice. The collet inserts are interchangeable. Most sizes are available in 4mm, 6mm, 1/8" and 1/4". You can't by collets separately (10,000pc minimum) but the knobs are cheap enough to sacrifice some if you need a combination that isn't available.
