dawsonaudio
My capstan motor isn't running at the moment on my mm1100. I took the sides off the machine and noticed that the wires going to the variable speed plug came loose. When I bought the machine, I noticed they were soldered to the connector, but coming loose. I left them the way they were as it didn't cause any problems with the machine. I since have had to rebuild my power supply and in moving all the cabling around inside the machine to clean things up, those cables came disconnected from the plug. I read an old post here http://www.groupdiy.com/index.php?topic=2993.20 that someone else had this problem.
There are 2 pairs of cables going to the plug coming off the main mda wiring harness. There is a black and white wire in each of the 2 cables. I've looked at the manual for my machine, but it only talk about a feed and return signal. Any idea which wires go where to get the capstan working again? I think that the 2 black wires were connected, but not sure on that.
I posted this over at the ampex list, but they are down due to the east coast storms I believe.
Nate Dawson
Nate Dawson
