Er.rrh! With my speaker designer's hat on .. ALL transduction principles have a bass/size/efficiency equation. The "moving coil" [1] version is well analysed.PRR said:The electrostatic direct driver has real problems with bass versus size. (Electrostat driver on a horn has interesting leverage but I've only seen it once ..)
The moving coil speaker as we know it is probably the only principle where a single unit can be designed such that in a suitable box, it covers 20-20kHz with good efficiency ... and more importantly, sounds like it does AND sound good! This has been possible since the 60s but it needed Aboriginal elder Neville Thiele to tell us exactly how.The moving-coil using iron and Cu/Al has VERY limited treble response, falling badly above 200Hz.
Actually R&K were the first to realise the implications of bass/size/efficiency. ie to get Bass, you had to reduce sensitivity. They invented Bass response. Before them, all progress was trying to make speakers louder, not better.They had the clearest-yet insight that the falling top response of the motor can balance the falling bottom response of a reasonable size diaphragm. That gives a speaker which sucks all over, reasonably flat. Their next insight was that the new world of tubes allowed use of a really horrible inefficiency by brute-forcing it with a massive WHOLE WATT of audio power to get perhaps 0.01W of acoustic power. They followed-through with extensive testing of various cone sizes and materials, and leaked the results so that commercial products were on the market before Bell got around to publishing their paper.
The paper was called "Notes on the Development of a New Type of Hornless Loudspeaker". Chester Rice went on to make significant advances in electrostatics, but nothing to equal the seminal R&K. Kellogg forsook audio to found his cornflake empire.R+K did not invent the cone/coil speaker. The paper you cite does not touch Horns except in passing (Kellogg did have a hand in an excellent horn driver).
