 slowly I'm going to start to list everything I have [ eventually  ]  keep bare essentials for the work I do currently
try to get to only having one or two projects on deck ! not recording full bands anymore so just not going to get to it
and getting ready to move in a couple of years
 May trade for certain things , BM projects although the idea is to reclaim space, money
and attention [ to other things ]
 Please EMAIL  gboboski at gmail dot com   PM BOX IS FULL on purpose , I see email quicker
May trade for MORE complete B.M. projects
 If no price means I don't know what I paid [ or what the cost is ], make "reasonable " offer
Wanted looking for,
 Vp 28 500 pre pair
1-Gix 51x tube pre
2- mic splitter Xfmrs
500 series eq's
parts complete 500 kits / un-built is fine if complete
I need one or two  Schoeps bodies ,
Omni mic pair of some decent sort
reverb store
https://reverb.com/ca/shop/okgb
WORKING GEAR
Likely too heavy to ship, but feelers on letting my 10" Tannoy's go
they are in a  box called Eaton, may never have another pair again so not selling cheap!
Onicraft GT-4  " passive " gates 2 for 50.00 !  need going through cleaning pots & connectors at the least
Bought these to mod , won't get to them but decent and usable as is
Peavey TMP-1 More old school than original design , only real  possible problem is
phantom power is 24v. not starved plate design , line in but not Hi Z in    89.00
Orban stereo sythn
Peavey speaker simulator D.I. passive , uses inductors 24.00
Mics
Apex 450 dual tube mic w/ psu & cable , seems to have a little noise [ sounds typical of a tube ]   99.00
easy fix swap one of the tubes out ,  even if you use it to mod or rebuild you're ahead of the game parts wise!
Misc  Audio Cylopedia  Fair condition
PROJECTS , some of these I've bought the commercial version and don't need more, so ............
2-M1 type preamp boards w/ Cinemag  8PCA input xfmrs Not in a hurry to get rid of these but if I got a good price
it's one less thing to build
NeveRange mid eq's , well the project as I started to put it together was the pultec midrange eq with
the neve line amps for make up gain with Sowter xfmrs , could consider splitting it up
390.00 is what I have in it [ the sowter's are expensive ! ]
Tube mic preamp G9! lunhdal inputs, faceplate pots , no pwr xfmr can throw in XLR's
Sontec Massenburg parametric eq project ON HOLD
pcb boards, faceplate and hard to obtain pot set, priced high because I don't really want to lose the chance
open to outragously high offers [ or really good trades of what I need ]
front panels w/ meter two pots and two rocker type [ c&k spst behind ] 2 for 20.00!
PSU pwr xfmr really for a tube amp with 500v CT winding plus 6v & 48v 49.00
PARTS / PCB's
2  SGA opamp kits
2N3055 Neve output stage transistors , 1 Motorola pair , the odd one out will be included with the toshiba pair
don't know the value yet so make a good offer if you want them!
Misc Xfmrs  1 - 600:600   15.00 2- 50k tube type one 9pin one 8pin [ 1 broken pin ] 2 for 10.00
Pair of Hadley output xmfr's
Hammond 850 , one L  [ E version is sold thanks ] 10.00 each
misc pcb's , two headphone amps you have to do the research , neve output stage , ssl sidechain
the balancer pcb included with any purchase ,  all boards 5.00 each or best offer
SSL / Aphex      , My friend has Some BUT he wants 20.00 each minimum 10 quantity
1537A  VCA's  14pin  higher quality ceramic type  last 8 I can find in my pile! 15.00 each
Ampex bridging xfmr pair Catalog number 4580200-01 gold pins 25 each
sifam mini meter, may have pair
UREI output xmfr pair 39.00
tube / discrete board from Millennia  TT eq , contains two of the millennia opamps  275.00 [ will entertain trades or offers ]
I have hand traced pwr & i/o pinout info but expect NO help from millennia , I planned to use it as switchable  tube / discrete
summing amp make up gain , or dual pultec output stage but have not gotten to it yet . [ I may eventually ]
story is I bought this from a member here who upgraded his millennia eq with a Forssell
board [ gotta say forsell has never been help with anything so don't bother ] so you are on your own
Expect No help from Millennia , in fact Joel WILL laugh at you as he admitted millennia is not worth the parts cost,
[ but he's actually quite funny ] so If you have a friend at a dealer with millennia product, that will not  help .
although tube paths are not too hard to trace
I/O relay pcb's & XLR's marked  F C S 2005 a good vintage well aged ready for use!
30.00 for 2 pair
Guitar gear
photobucket was down but
 Guitar tube preamps
Hafler Triple Giant
Ada  midi tube pre
Freebies [ with purchase cause then you've already got some of the postage paid for ! ]
prosumer camera mic  has multi pin [5 ] connector,
pultec midrange eq pcb's , these were included in some deal so free with any purchase
6386 tube , Yes say you own one [ one side does not test good ]
1- Dan Kennedy's opamp expierimenter pcb's space for one 8pin dip & both regulators
no info you'll have to be a little clever, free with any purchase
Living sounds mix stick etched not drilled , free with any purchase [ one left ]
Mega Mod Meter [ say that as many times as you like! ]
bezel is 5" x 3" meter is 4 5/8 " x 4 1/8 " free with purchase
fet d.i. input  either someone gave it to me or sold it cheap,  free with any purchase
from a retro fitted mixer [ buffer boards ? ] uses a 301 I.C. [ socketed ] i'll throw two free in with any order
4739, they are obsoleted parts with no equivalent
Mallory  MGLL8 Dual stereo L pad  8 ohm 50 watt   20.00 o.bo.
inductors from Yamaha board will post the values 1.00 each
1/4 D shape knobs
« Last Edit: June 24, 2019, 12:12:31 PM by okgb »
ruairioflaherty
Your for sale and free threads were always legendary!  Great to see the old Black market back.  I'll do a clearout too later this week, I may even do one of my fundraisers for the forum.
Re: Fs / ft xfmr's meters switches & more ! 16.07.12
« Reply #2 on: July 16, 2012, 10:27:03 AM »
Bump for items added , thanks
Re: Fs/ft xfmr's meters switches & more ! 18.07.12
« Reply #3 on: July 18, 2012, 04:30:20 PM »
I Like to hear myself bump , so ...............
Re: Fs/ft xfmr/ meters switches & more ! 24.07.12
« Reply #4 on: July 24, 2012, 10:56:18 AM »
more items , some new prices
« Reply #5 on: July 25, 2012, 11:47:31 PM »
Greg,
Do you happen to know what the sensitivity range is of the compression meter?
kpearsall
« Reply #6 on: July 26, 2012, 12:38:09 AM »
PM'd about Grayhills
a soBer Newt
« Reply #7 on: July 27, 2012, 05:05:43 AM »
How much for the complete Ward beck?
kepeb
« Reply #8 on: July 28, 2012, 12:50:57 PM »
Hey.
I could do with some of your vents! at least 3, 5 would be nice :)
I'll take a pair of your greyhills to get them here
is that ok?
pyinag cosle aentttoin
« Reply #9 on: July 28, 2012, 07:40:32 PM »
The Ward Beck is no longer intact [ 2 modules short ] but I wasted waay too much time getting shipping quotes
for people who flaked , so not likely to bother selling it whole .
grayhills are gone , I'll gladly give as many vents as you like , if they didn't have the tabs could mail them in an envelope
but they are a little " light duty " plastic
« Reply #10 on: July 28, 2012, 10:42:37 PM »
 . . . . so I take it you have no idea what the rating is for the compression meter?
« Reply #11 on: July 30, 2012, 02:21:33 PM »
comp meter came from shure mixer , no real markings on it but how can you NOT have it ?
would you like fries with that ?
envelope
« Reply #12 on: August 07, 2012, 05:03:25 PM »
Hi Greg, I got the box of stuff. You're packaging is excellent and everything arrived in perfect shape. Thanks for the extra bonus stuff too!
Re: Fs/ft Magic Big KNOB + various parts, xfmrs , meters 13.08.12
« Reply #13 on: August 13, 2012, 12:37:34 PM »
Good to hear !
And Bump for Fantastic one time only offer !
spase
« Reply #14 on: August 28, 2012, 08:45:25 PM »
pmed again your inbox its full :)
Re: Fs/ft Magic Big KNOB + various parts, xfmrs , meters 01.09.12
« Reply #15 on: August 31, 2012, 12:06:58 PM »
Yes it is , the top of the post asks to email me please
[ I'll see it and respond sooner that way ]
Re: Fs/ft Magic Big KNOB + various parts, xfmrs , meters 09.10.12
« Reply #16 on: October 09, 2012, 12:42:21 PM »
New items bump
Re: Fs/ft Magic KNOB + various parts, xfmrs , meters 15.10.12
« Reply #17 on: October 15, 2012, 06:39:24 PM »
New bumpito for you
Re: Fs/ft Magic KNOB + 312 pres , parts, xfmrs , meters 24.10.12
« Reply #18 on: October 24, 2012, 12:23:31 PM »
Bump for update
myker
« Reply #19 on: October 24, 2012, 02:07:31 PM »
Hi, your PM is full. How much for the API compressor?
Last post April 03, 2008, 08:21:33 AM
by peter purpose
Last post February 20, 2021, 04:30:36 AM
by TwentyTrees
Last post November 18, 2018, 01:27:26 PM
by Gold
Last post December 20, 2020, 09:04:37 AM
by Helios67
