electric_diaries
Hey guys long time listener first time caller. I am just in the process of making a mixer and was hoping for some help/feedback/critisism on a part of it. I have built a few before and have read the Meta on mixers and have found it of great use however I am still in need of another opinion.
The mixer will have 24 channels in total. 8 left, 8 right and 8 with pan and volume control. It uses a 24>4>2 mixing network using discrete mixamps as seen in this block diagram. http://imageshack.us/f/23/blockdiagram.png/ The inputs will mostly be fed from a soundcard.
In the picture below is what I have proposed for the 8 channels (only 3 shown) which will have volume and pan options. After these 8 channels have been summed into a stereo pair they will then be mixed with the sum of the 8 hard left and 8 hard right channels respectively in a second stage of mixing as shown in the block diagram. http://imageshack.us/f/692/mixere.png/
My questions are:
-Can anyone suggest values for RX, RY and the pots?
I have toyed with a few values but I'm still unsure how to split the pan feeding and exiting resistors. I think in the past I used to use 3K6 for both RY and RX with a 2K2 lin pan pot but am thinking that maybe I should be using a higher impedence? usually 10k for the volume pot too.
-would I better off to go with a design like this? (perhaps without the shunt resistors) http://sneak-thief.com/passivemixer/balanced_PassiveMixWithControls.pdf
-Any thoughts on the proposed grounding and shielding?
I'm very open to any other suggestions and comments too.
Thanks so much for your help! - Benjamin
My questions are:
