Help needed identifying power connector on Calrec ZN3018 PSU output
MeToo2
The Netherlands
Hoping someone can help me identify a connector on the back of a Calrec ZN3018 linear power supply that I want to use to power my DIY rack.
It's marked "RS" (presumably RS components) and has 8 sockets (of which 6 are in use). Pinout is obvious (printed on the chassis).
It is circular and has 3 locating pins spaced at 120 degrees to mate with the shield. Overall diameter of screened portion is approx 19mm.
There are also 5 location slots in the inner black ring. Approx located @ 12 (wider) 4,5, 7,8 o' clock (narrow)
For scale you can see a standard IEC connector next to it as well as a 4mm banana post.
If I can't identify it I guess I'll change it out for a modern equivalent as technically it's nothing special.
Edit: just google image browsing. Could it be MIL-C-26482 Circular? = British Standard BS9522? Shell size 12-08 pin?
Looks very much like an Amphenol RT360 8 pole. And the good news is that aren't too expensive compared to their MIL counterparts (if it fits).
Sorry I found it tough to get the camera to focus properly.
Looks very much like a standard "Burndy" type connector:
http://uk.farnell.com/burndy-fci/utg014-12s/circular-conn-rcpt-size-14-12pos/dp/1129557
Jakob E.
Jakob E.
Indeed. Thanks!
Mating component should be UTG6128P
