Volume11
Re: D-U67 Tube Mic Complete PCB Kit (Pre-Order) New U87 PCB for U67 body
« Reply #240 on: October 07, 2012, 02:34:00 PM »
I have been working on validating the last details regarding mouting the AMI boards and last fine tuning regarding the Clearance of the track pad in respect to th railing and position,  fit in the mic boady and hole tolerance ,  I am pleased to annonce that all my concerns on this have been validated ,
here some
AMI  or External Board Mounting Hints and clearance railing test,  :)
and Yes this is My favourite Celebration beers the Boddingtons  ;D
Hey Dany, I am now to this point in the build and I was curious as to how you actually mounted the transformer in relation to the rails. Did you mount the pcb first, then solder the transformer from the other side, making it basically permanently mounted? I'd like to have the option of removing the transformer without desoldering it. I was thinking of cutting away some of the rails on the side that the pcb won't be mounted to.
Re: D-U67 Tube Mic PCB Kit (Sold Out)// D-U87 PCB/ New D-U47FET (Sold Out)
« Reply #241 on: October 07, 2012, 05:08:11 PM »
The things is that the PCB take cares of the connection for the tranformer but that can be done manually if you look at one of my pitcure in the WM at the end i did not use the pcb and mounted the tranformer on the side inside the bottom end of the mic ,  so at this point i sont see no problem using it that way ,  this is the beauty of DIY  ;),   but it is easier to use the mouting pcb for the AMI if you plan to remove it just dont use too much solder a tad of it will do just fine ,
hope this  helps,
Dan,
Re: D-U67 Tube Mic PCB Kit (Sold Out)// D-U87 PCB/ New D-U47FET Available Now
« Reply #242 on: October 07, 2012, 05:28:03 PM »
OH, I took too long ...   :(
Are you going to do another run?
I am planning to but I will wait a bit as i would like to have some feeback first ,
interested in 2 DU67 and 1 DU47fet if another run  :)
as soon as the initial feedback comes in i will check on having another run,
I will keep you posted,
thanks,
dAn,
« Reply #243 on: October 08, 2012, 07:30:22 AM »
dAn, i would like to build u67 or u87 (or both)... i don't come often enough on the forum to know when it's ready is there a way to get specific newsletter on your release ?
(+ i have a virus alert on the first page because of images from "odysseedupixel[DOT]fr" of this forum so i can't read if important informations there)
« Reply #244 on: October 08, 2012, 07:58:38 AM »
47fet boards recieved in Sweden today :)
wave
« Reply #245 on: October 08, 2012, 09:21:32 AM »
You can enable notifications via email for each thread you have posted in. So you would push the notify button next to the reply button at the top or bottom of the page and that way when Dany updates the availability of the PCBs on the thread, you will be notified that a new reply has been posted. It will email you for every new post not just Dany's (specifically) though.
Hope that helps,
Dave
Volume11
« Reply #246 on: October 08, 2012, 04:51:35 PM »
Hey guys, am I suppose to match the numbers on the jack to the numbers on the pcb when wiring it up? I was under the impression that the red wire, #4, was B+ but, if I match the numbers up then yellow goes to B+. Am I looking at this wrong? I matched the pin out numbers on the mic jack to the cable. On the schematic it shows mic 1 - 7, and it matches the pcb, obviously but, I would hate to proceed and mess something up.
Delta Sigma
« Reply #247 on: October 08, 2012, 05:16:04 PM »
Received my U67 boards on Friday, impressively quick! Happy Thanksgiving and hope you're not too big of an Alouette's fan.
tskguy
« Reply #248 on: October 09, 2012, 08:23:14 AM »
Volume11,
You may be better served by asking build questions in the build thread. It will also assist other builders that may have the same question!
Eric
Volume11
« Reply #250 on: October 10, 2012, 04:36:19 AM »
Volume11,
Eric
My bad, I'll pay closer attention next time. Almost finished, can't wait to fire it up.
Cardinen
« Reply #251 on: October 10, 2012, 12:24:21 PM »
U87 Board Arrived today!
Cardinen
SSLtech:  "Because not all that matters can be measured, and not all that can be measured matters."
Hank Dussen
« Reply #252 on: October 12, 2012, 06:39:23 AM »
D-U67 and D-U47 PCB's arrived here in Belgium...
BigDad
« Reply #253 on: October 13, 2012, 08:41:42 AM »
Hi everybody,
I'm new on this forum and i'm really interested by the PCB of the U47fet and U87
i've just two question :
1 - The U47fet's PCB was Sold Out ! When y 'will be a new stock ?
2 - The U47fet's transformer it is the Sowter 1303 ? Where buy it ? On the sowter's website i've not find the 1303 !
Thank You
PS : Sorry for my bad english, i'm french !
"Technology is a seductive b****, she will seduce you. You press this button, you don't have to do anything. But analog is the love of your life. You can push real hard and it always gives back. [...]
0dbfs
« Reply #254 on: October 13, 2012, 11:09:08 AM »
Second batch of 67-ami/ext and fet47 boards arrived. Thanks Dany!
jb
Music is everything!
Audio is everything else!
« Reply #255 on: October 13, 2012, 11:29:05 AM »
Hi everybody,
A: i am waiting for initial feedback before i issue another batch ,  hope to be really soon,
A: contact direct Brian sowter [email protected]
Thank You
PS : Sorry for my bad english, i'm french !  A: your english is fine,
BigDad
« Reply #256 on: October 13, 2012, 04:18:44 PM »
Really thanks poctop !
I think i go to wait the U47fet's pcb for buy the two mic's pcb in same times ! Meanwhile i will contact Brian Sowter !
Thanks and Great Job poctop !
strangeandbouncy
« Reply #257 on: October 15, 2012, 04:32:40 AM »
Hi Dany,
   still not arrived here in UK. Should I be worried? Anyone else in UK received yet?
   Kindest regards,
     ANdyP
. . . . RUH ROH . . . . .
« Reply #258 on: October 15, 2012, 02:09:51 PM »
Hi Dany,
   Kindest regards,
     ANdyP
Hi Andy ,  I have shipped your order on september 16 th,  in the very worst case scenario it may take up to 6 weeks but is usually much quicker than that ,  give still a bit of time and if you did not receive anything after week 6
i will send you a replacement order,  Hang in there i hope it should be really soon ,once again i am sorry to make you wait such a long time ,
Best ,
Dany,
strangeandbouncy
« Reply #259 on: October 15, 2012, 04:19:24 PM »
Hi Dany,
   I certainly don't want to hassle you! I am hangin' in there, and will keep you posted.
   Many thanks,
    ANdyP
