Re: (D-U67 Tube Mic PCB Kit // D-U87 PCB// D-U47FET) All Available
« Reply #320 on: November 20, 2012, 07:20:42 PM »
payment sent for u87 taper
Phrazemaster
« Reply #321 on: November 20, 2012, 07:25:18 PM »
PCB's arrived, thanks Dan! :)
** * Kablooie!
« Reply #322 on: November 21, 2012, 09:09:42 AM »
payment sent for 1 D-U67 MKBV12  and u87 taper .
Thanks Dan
madreza
« Reply #324 on: November 24, 2012, 12:59:05 PM »
Received !
Thanks my friend ;)
( and .... great work ;) )
Knight 1: We are now no longer the Knights who say Ni.
Knight 2: NI.
Other Knights: Shh...
Knight 1: We are now the Knights who say... "Ekki-Ekki-Ekki-Ekki-PTANG. Zoom-Boing. Z'nourrwringmm.
« Reply #326 on: November 26, 2012, 07:05:40 PM »
hi
payment sent for 1 D-U67 AMI/Ext
yeah
« Reply #327 on: November 28, 2012, 06:34:33 AM »
Pcb  received
Thanks Dan !
« Reply #329 on: November 29, 2012, 01:01:16 PM »
PCB arrived today   :D
thanks!!!!!!
« Reply #330 on: November 29, 2012, 04:45:47 PM »
Payment sent for two D-U67 AMI/Ext.  Looking forward to getting them.
Earl
« Reply #332 on: December 10, 2012, 03:20:32 PM »
pcb received
thanks  Dan
« Reply #333 on: December 17, 2012, 10:45:20 AM »
Hi All, i have been shipping this morning the last order ,  the store will be open for today only and then will reopen January 7th 2013,
thanks to all of you for your interest on those project , :)
Dany,
Store Closed Back January 7th,
Merry Christmas to All,
C and B  ;D  and i just survived the end of the world  8)
Merry Christmas,
Dan,
« Last Edit: December 21, 2012, 02:03:56 AM by poctop »
ok about that european question again. i red all but  to make sure my english is good enough so i don't blow up the house. the only 2 things i have to change are :
this power transformer 546-187B20
by this one : 546-186B20
and this lamp 606-1052A6
by this one 607-1031QD1
will this fit without directly with no other modifications ? (thx for your help)
wave
Both of those substitutions will work fine.
Dave
So these are the final Version , the square version (44mm * 48mm) should fit the gt-2b style , and the round version is 60mm diameter should fit upcoming riggler mic body
i have been able to fit 2 mounting hole as per riggler drawing of 5.05mm mouting , i am to produce gerber at the moment so i will probably run a very small batch of those , so if any interest let me know ,  this will be an experiment for sure ,  there is 2 versions of each to accomodate the M49b and M49c version.
Stay tuned ,
M49b mini driver round   Note : the Bypass cap will go underneath the first plate as it is not show here only connection point ,
M49c mini driver round
M49b mini driver square
M49c mini driver square
« Last Edit: December 31, 2012, 09:08:15 PM by poctop »
Just a question about the m49 builds. In order to build these you need to get your hands on a ac701 right? Pretty expensive for the DIY community... Any chance of a mod to use ef86 or something similar?
Emil
