wolan42
Hello Dan,
boards arrived today. ;D
Andreas
Shipped to France : Salut Les cousins ,
to Australia : Thanks all Mate,
and to US :)
Dan,
Since i have been Given an EF800 and EF802 from Oliver,
I will have this coming soon , just in case some folks would be interested,  it should fit this body perfectly as well looks like same footprints as equinox,
EF800-EF80-EF802  D-47 with AMI T47 and Classic BV08 from AMI support
reed relay for True Omni switching from the psu rocker switch.
just need to Finalise the modification of the 2469P Passive  psu and test it ,
Dan,
DjaiTeam
Hi DAn,
This looks very nice, prices?
I happen to have a Cinemag cm461 nico transformer, will this fit in there?
Iwan
Hi DAn,
Iwan
Thanks here it is , D-47Ef800
I have made them specially for the aMI T47 or the classic series BV08 from Tabfunkenwork,
not sure if the 2461 will fit but if you measure the winding section i can let you know if it will ,
DjaiTeam
This should be it! Thanks for your effort..
Shipped to US, Thanks,
I should have those EF800 U47 PCB soon also if anyone interested see above post ,
also the a new offerings for the U87 single board should be here soon ,
Thanks All,
Dan,
mgronroos
That D-U87 looks too nice to resist, I'm in!  :)
//Michael
If you can't sample it, it doesn't exist.
burglar
New 87 boards look great, are they designed to fit syt-5 size body as well as the standard mxl taper bodies?
