Vintage Tube & Vintage FET Microphone PCB Kit For DIY & New D7 Custom Capsule
Payment sent for two D-U67 AMI/Ext.  Looking forward to getting them.
Earl
Hi All, i have been shipping this morning the last order ,  the store will be open for today only and then will reopen January 7th 2013,
thanks to all of you for your interest on those project , :)
Dany,
Store Closed Back January 7th,
Merry Christmas to All,
C and B  ;D  and i just survived the end of the world  8)
Merry Christmas,
Dan,
ok about that european question again. i red all but  to make sure my english is good enough so i don't blow up the house. the only 2 things i have to change are :
this power transformer 546-187B20
by this one : 546-186B20
and this lamp 606-1052A6
by this one 607-1031QD1
will this fit without directly with no other modifications ? (thx for your help)
Both of those substitutions will work fine.
Dave
So these are the final Version , the square version (44mm * 48mm) should fit the gt-2b style , and the round version is 60mm diameter should fit upcoming riggler mic body
i have been able to fit 2 mounting hole as per riggler drawing of 5.05mm mouting , i am to produce gerber at the moment so i will probably run a very small batch of those , so if any interest let me know ,  this will be an experiment for sure ,  there is 2 versions of each to accomodate the M49b and M49c version.
Stay tuned ,
M49b mini driver round  Note : the Bypass cap will go underneath the first plate as it is not show here only connection point ,
M49c mini driver round
M49b mini driver square
M49c mini driver square
Just a question about the m49 builds. In order to build these you need to get your hands on a ac701 right? Pretty expensive for the DIY community... Any chance of a mod to use ef86 or something similar?
Emil
