Re: Vintage Tube & FET Microphone (D-U67 D-U87 D-U47FET D-M49 D-M269c)
« Reply #421 on: March 24, 2013, 10:52:35 PM »
This is the D-M49 round 60mm version example,
Best,  :)
Dan,
Winetree
« Reply #422 on: March 25, 2013, 02:50:02 AM »
Will the D-M49 round 60mm version work in the mxl 990 body? or any other chinese bodies?
Toure14
« Reply #423 on: March 25, 2013, 04:26:27 PM »
Just paid for 1 External u67 kit... ;D
kpearsall
« Reply #424 on: March 25, 2013, 07:59:09 PM »
I doubt the MXL 990 would hold it, but specs say the outside dimension of the 990XL is 71mm x 160mm... .Could be a good candidate! I haven't pulled one open to see how it could be mounted though
« Reply #425 on: March 25, 2013, 10:55:02 PM »
the puck is 4 inch from top capsule mount to pcb base, ? and 60mm dia
Dan,
« Reply #427 on: March 27, 2013, 11:51:10 AM »
Here it is, the process is started  i got that neumann capsule on ebay and cleaned it a bit and i will try to put it in all the other mic as i go and take a shot at it ,
Here with the D-M269c and the restored neumann capsule back to life again,
https://io.groupdiy.com/file/gdiy-2017/u/39511/58d0281993c65.wav
Dan,
« Reply #428 on: March 27, 2013, 01:24:56 PM »
Important Notice
I just updated the BOM for the passive 2649 psu to include a revised  250 ohm Heater trimmer that will work out adjusting to  4V 100ma consumption,   so if you stick a 39 ohm between pin 4-7 and you adjust the voltage to 4.0V,  the initial 100 ohm value got at 4.4V at 100ma at minimum , so this pot will work for those lucky that will try an AC701 someday,  keep in mind that it has been mostly calculated for higher current higher voltage 5840W tube , but this pot will cover the range better for both type tubes,  Just a precaution for slowly ramping heaters on gentle tubes,
Dan,
kpearsall
« Reply #430 on: March 29, 2013, 03:15:02 AM »
paypal'd for DU-269 PCB set and Cap kit :)
0dbfs
« Reply #431 on: March 29, 2013, 05:00:02 PM »
Paypal'd for:
A bunch of mic stuff :)
Heating up the iron!
-jb
Music is everything!
Audio is everything else!
« Reply #432 on: April 02, 2013, 09:45:42 AM »
2* D-M269c Kit left ,
4* D-M49 Square Kit Left,
4* D-M49 Round Kit Left,
Tube Socket = Sold out .
I will be shipping all paid order this morning ,  :)
thanks All and happy mic building
Dan,
« Reply #433 on: April 03, 2013, 10:16:13 AM »
Shipped this morning ,  :)
Dan,
Toure14
« Reply #435 on: April 05, 2013, 06:23:34 PM »
i would like to purchase a 269c kit but when will you have more tube sockets in? does mouser supply a tube socket?
« Reply #436 on: April 05, 2013, 07:08:38 PM »
The D-M269c does not require a tube socket ,  the tube is mounted on turrets,
DAn,
Toure14
« Reply #437 on: April 05, 2013, 08:33:33 PM »
cool....2 days ago you posted that you only had 2 kits left, is one still available along with the styroflex cap kit? if so I will order now.
Also I was wondering if the flat smooth surface switches can be installed on the mic like the switches currently used on the u87ai instead of the metal throw switches for these mic builds?
micaddict
« Reply #438 on: April 06, 2013, 06:36:35 AM »
Darn!
Oh well, he'll make a new batch, I'm sure.
This is just warming up.  8)
« Reply #439 on: April 06, 2013, 11:23:31 AM »
i do have 2 sets lefts,
the switching pinciple and pcb is the same as in the large U87 and u67 type mic,
