I'm experimenting with an A-D, using a CS8406 as digital audio transmitter in 'Hardware Mode -A-', slave,
transmitting through AES cable recording to an old Fostex D-5 DAT,
The fact:
Independently of the OMCLK, BCK, LRCLK settings,
the DAT recorder locks to the 44.1kHz only if I set the COPY/C port [pin 1] low,
and 48kHz if the port is high.
Do you think this is normal?
If yes, what are the combinations for the other sample frequencies? (88.2, 96, 174 and 192)
Suggestions welcome.
The fact:
