bernbrue
Re: D-U47FETi Microphone Project ( Looking For Donor Body Suggestion Welcomed)
« Reply #20 on: September 07, 2012, 02:37:22 PM »
ISK Tm-66 ?
dimension Still unknown ?
Dan,
it seems to be the same as the T-Bone SCT-700. It measures 59 x 180 mm
regards
Bernd
MicDaddy
« Reply #21 on: September 08, 2012, 11:28:43 AM »
I've been sitting on a 'Dale' m7 and this may be just what I was looking for.
« Reply #22 on: September 10, 2012, 02:33:00 PM »
this is i would think the last version,  it 44 * 48 mm , with grapping hole at 1/4" and specific at 28mm center from the bottom of the board,  Meant to  fit tbone, nady and gt-2b style mic   i will be doing a very small run to start with. Let see What happens,
Let me know if there is any interest. :)
Dan,
« Last Edit: September 14, 2012, 12:40:40 AM by poctop »
KasperNyhus
« Reply #23 on: September 10, 2012, 06:45:38 PM »
I'm in for one!
signalflow
« Reply #24 on: September 10, 2012, 07:10:38 PM »
Holy Crap! You're killin me! I'm in for 2 depending on price.
-Casey
The shortest distance between two places is a nap.
« Reply #25 on: September 10, 2012, 07:13:59 PM »
Interested!
« Reply #26 on: September 10, 2012, 07:37:29 PM »
1 please
JamesW
« Reply #27 on: September 10, 2012, 08:12:08 PM »
A pair please.
Subject to change with out notice
mukole
« Reply #28 on: September 10, 2012, 09:01:49 PM »
I'm definitely interested in 2 as well please!!
MicDaddy
« Reply #29 on: September 10, 2012, 10:53:55 PM »
I'd like 2 please
Govinda Doyle
« Reply #30 on: September 11, 2012, 08:48:54 AM »
1 for sure!  :D
baadc0de
« Reply #31 on: September 11, 2012, 09:01:51 AM »
Pair here.. add to the U67/87 boards.
EDIT: One more question, does anyone know if the PCBs would fit into the LDC part (MXL 550) of the MXL pair quoted before?
« Last Edit: September 11, 2012, 09:17:19 AM by baadc0de »
« Reply #32 on: September 11, 2012, 10:46:57 AM »
I beleive the MXL is 47mm outer that should leave enough room for the 44mm PCB but this will be part of the experiment on MXL body type For sure.
DAn,
MatthisD
« Reply #33 on: September 11, 2012, 11:15:46 AM »
DAn,
The se2200a body is the same diameter. The PCB mounting holes are only 29.5mm apart. I think the 44mm PCB would have to be trimmed down by a couple of mm on each side unless you can mount the PCB right on the centre diameter some how.
Matt
0dbfs
« Reply #34 on: September 11, 2012, 12:51:53 PM »
Two for me please!
Thx!
-jb
Music is everything!
Audio is everything else!
dissonantstring
« Reply #35 on: September 11, 2012, 12:54:19 PM »
hi dany,
interested in one DU-47 FETi pcb set.
thanks!
best,
grant
craigmorris74
« Reply #36 on: September 11, 2012, 01:55:58 PM »
I'd like one.
Craig
jonhunter
« Reply #37 on: September 12, 2012, 01:15:54 AM »
I'd Like two !!
thanks
jon
Jon Hunter
Hank Dussen
« Reply #38 on: September 12, 2012, 02:47:59 AM »
1 here!
« Reply #39 on: September 12, 2012, 02:52:32 PM »
DAn,
Matt
The things is i have no clue of the railing dimension inside all i was refered too is the Alctron PCB size and they have been created according to that at this point ,  i did a small batch tough so if they are any correction in term of  dimension i will be open to suggestion no problem,
Dany ,
Last post January 10, 2021, 11:27:41 AM
by Naterbater
Last post August 23, 2013, 11:22:27 AM
by Enchilada
Last post January 17, 2021, 07:45:16 PM
by Purplenoise
Last post November 20, 2020, 10:34:42 AM
by doqmemory
