chunger
A bit of a newbie question here. Just checking to see if there are particular parts of a microphone's internal wiring that require "special stuff".
I've been using stranded silver-plated teflon wire for everything in various gauges and have not had problems, but wanted to know particularly with high impedance sections, capsule connections, etc. what I should be using. If the silver teflon wire is good, what gauge should I be using optimally? I'd like to stock up on various colors of the proper gauges so I can make the internals clean and legible for diagnosis. Thus far, my default is to simply use bigger wire if unclear and it has not adversely effected any of my builds.
I'm sure there is a lot of voodoo out there surrounding the use of various wire types, but if there is even marginal advantage to using certain types for small-scale DIY, I'd be interested being a little bit uncompromising to give my projects the best shot at success.
(Edit)
Found some answers. It seems many top-end builders use stranded 28 AWG PTFE (teflon) silver plated wire for capsule connections. The high insulating properties of PTFE seem to be desirable, but as gauge increases, the wire can be microphonic, so 28 AWG seems to be the sweet spot.
(Edit)
